Anybody know the maximum valve lift with standard GX springs?
From Las Vegas USA
I'm in the process of checking the valve geometry for the new camshaft I fitted. I noticed that the GX valve springs appear to be very close to coil bind. I'm using all stock GX retainers valves dbl springs etc. The valve lift is .435 and at full lift there is .020 between the middle 3 coils (I realize the proper way to measure is with the spring out) , some cam manufacturers spec .050 some .060, I'm likely going to have to measure a spring to be sure but figured I'd check here first................figuring maybe someone knows what the max lift is.
Tom
Posted on: 2011/8/1 7:12
Re: Anybody know the maximum valve lift with standard GX springs?
From Sydney
I have noticed that the clearence between spring retainer to the top of the valve guide [with stem seals] can be an issue as well.
Posted on: 2011/8/1 7:31
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
I don't know the answer, but:
* GX camshaft lift is only .311" (cam lift)
* Nissan Competition springs were good for at least .468" and required special retainers.
Posted on: 2011/8/1 8:08
From Sydney
That calcs to ~.445" valve lift. That leaves ~.020 of lift margin. [calculated with a 1.43:1 rocker ratio]
Posted on: 2011/8/1 8:30
1970 KB10 Coupe
S13 caliper b...
From mandurah
My cam has 298 lift at the cam ,and with stock rockers they were realy close ,so now I'm putting performance dials on ,there designed for large lift cam and are well priced
Got mine through bige
Posted on: 2011/8/1 9:19
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Jesse are you sure that's the lift? Thought you had a bit more than that, or was that the old cam?
Posted on: 2011/8/1 9:26
From mandurah
The other cam darren wanted me to use had 470 at the lobe ! So yea this one has 426 lift at the valve but still a fair bit of duration
Posted on: 2011/8/1 9:32
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From sydney.nsw
THATS HUGE 470 at the lobe = 672 at valve,THATS THE BIGGEST DATO GRIND I EVEN SEEN,( them springs won't handle that)HAHAAAAAAAAAAAAA. 470 at valve i think.
Posted on: 2011/8/1 9:45
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
