Re: B310 Wagon Diffs
It's a bizzarre code as it doubles up on the 'V'
The VB310 part is obvious enough, but the suffix VRM breaks down as
V= Panel van
R= 2 door
M= Australia
I had believed that B310's were imported while local production capacity was used in the manufacture of the larger P810 & P910 series of cars. Can anyone verify?
It used the H150 rear end. I don't think that the Borg Warner was seen on anything other than the locally built B210 [120Y] sedans from July 1976 untill the end of 120Y production.
The same happened with the P810. A Borg Warner rear axle was introduced in about '78 or '79, but the following model P910 Bluebird did not use it at all & it had the H165 & H190 diffs instead.
Posted on: 2006/4/2 8:44
Love your Datsun.
Treat it well.
Ah, how much we have learned in the past 9 years.
M suffix = Australia market, not necessarily Australia-assembled
V suffix = Panel Van
http://datsun1200.com/modules/myalbum/photo.php?lid=25699
VB310 = Van (called wagon in Australia)
WB310 = Wagon (called Sport wagon in some countries)
VB310 "Van" (Wagon)
WB310 "Wagon"
All use H150 diff. VB310 had leaf springs, while WB310 had 4-link coilover
Posted on: 2015/6/4 23:31
From Quairading, Western Australia
early 120Y's had H145's... my July'74 120Y 4 door sedan had one, but now has a BW68 in it...
Posted on: 2015/6/5 9:42
Atheism is a non prophet orginization
Yes, all Japan-built 1973-1974 B210 were fitted with H145
Is your 120Y a 1974 model? If not then the rear axle assembly was swapped sometime in it's long life.
Posted on: 2015/6/5 9:50
yeah July '74, and I took the H145 out and replaced it with a BW68 out of the original Defect which was/is a March '77.. and THAT car was an aussie built one... strangely it had Jap spec struts on it...
wanted to put a H150 centre into the H145 housing but the axles wouldn't come out and the car was bouncing around on the hoist, so I put in the Defect's diff drum to drum with the leaves and everything... and the 200B SX alloys wit R14 185/65 tyres... and for an A12 it's for it wild tyre size, but TD3 does have a 60L 4 speed in it...
also didn't have a manual tailshaft for it - car was a 3N71B car... and didn't want to buy a manual tailshaft.... and the BW68's good..
and I did learn one thing... the rear track of a BW68 in a 120Y is wider had Bluebird steelies on my black 120Y and the tyres scrape against the leaf springs, on TD3 those wheels/tyres clear the leaf springs..
edit it has 185/75 R14 90 H tyres on the back of it and 12" rims and tyres on it...
Posted on: 2015/9/11 9:57
Edited by Mawler1 on 2015/9/12 14:08:46
From Sydney Australia
Actually the Australian VB310 Sunny Panel van was leaf spring as elsewhere and solid sides no windows at all and like all Sunny B310 models in Australia full imports, they were all also just a cooking A12.
Mine went through A14 GX then L20B which even in SSS spec went no better than the A14 GX engine both ran the appropriate 5 speed so ratios were similar between the overdrive type 60 and the overdrive type 63 boxes, However man did it stop when I dropped in a spare set of Works Stanza struts works vented disks and four spots strangely enough brake balance with stock rear drums worked out perfectly with that setup.
Wish I still had it as they were rare back then let alone now, Six years ago when I was working in Bowral in the Southern Highlands one of my Customers had a Sunny van and his checking found just one other registered in NSW at the time.
Posted on: 2015/9/13 20:25
Here are two Australian VB310V.
This style was not produced in Japan (2-door van with small middle window).
Posted on: 2015/9/13 22:34
Quite a regular
From Wollongong
I got one for sale on gumtree at the moment location Wollongong NSW Australia 😎
Posted on: 2016/9/24 15:20
From sydney australia
The Sunny Van I had was a 11/78 Japanese made, round head light, leaf spring A12 powered version. It had side windows, but smaller than the ones in the photos. I don't know if this was factory or aftermarket, as the previous owner had also removed the welded in shelf to fit a rear seat. The good news is the fellow I gave the shell to is restoring it because it's in better condition than his one. I can also remember selling some rims to a father/sun combo, for the sons Sunny Van, which was white with solid sides. Suggested an A15 to the father (I was selling one at the time) but no sale.
Posted on: 2016/9/24 23:45
2-door van for sale
does it have a standard diff, or a Borg Warner?
Posted on: 2016/9/24 23:46
Edited by ddgonzal on 2016/9/25 0:02:37
« 1 (2) 3 »
