Best way to lower the back?
From Vancouver WA. U.S.A.
What is the best way to lower the the rear of a coupe, I want to get it to match the front but dont want to sacrifice ride or perfomance ? Open in new window
Posted on: 2006/5/1 5:39
BE sure to check out my coupe build thread and feel free to leave comments good or bad.
[url=http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=36107&fo
Re: Best way to lower the back?
Lowering blocks. Cheap, simple, easy to do, reversable. Just get longer u-bolts. May not be legal in some countries.
Theoretically, re-arching the springs is better, but you'll probably want to take it to an expert to do that.
Posted on: 2006/5/1 6:57
I thought I read somewhere that you can flip the springs upside down? The previous owner gave me a set of lowering blocks for the rear, so maybe I will just use them. I am not sure how they lowered the front I havent even had a chance to look it over well, basically I seen it bought it, loaded it and unloaded it in about 1 hour and it was 35min form my house. I did start it and noticed it needs a water pump
Posted on: 2006/5/1 7:01
looks like a good buy
lowering blocks are the quickest and easiest way t lower the back, and cheapest if you've already got them.
out of interest have you got any pics of your chev 4x4 with 18" of lift ?? would luv to see some ??
Posted on: 2006/5/1 7:54
From Canberra, Australia
If you flip the leaves, over, it is only the main spring you flip over.
so you have to take the other spings off, flip the main one over and then reattach them again.
I think I would want a proper suspension place to do that.
Blocks would be alot easier.
Posted on: 2006/5/1 7:59
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
The 'best' way to lower it is to have the springs reset. Having the main leaf reversed as part of the whole spring rebuild process is a good idea.
Now, you can't have it both ways. If you lower the rear, you will lose some of your ride quality, no matter how you do it. If nothing else, you will have less axle travel available, & if the rear springs are properly reset, the ride will be a little stiffer as well. It's all a matter of balance. The more you lower it, the more you will pay for it in other ways that relate to ride & comfort.
Posted on: 2006/5/1 10:24
Love your Datsun.
Treat it well.
From Geelong, Vic
flipping springs isnt that hard, all you need is a vice and a longish bar to centre the springs when you put it back together
im still alive, so its not dangerous
Posted on: 2006/5/1 12:13
Yes, with the sedan, but no with the Coupe. With the coupe, the shocks stay at the place relative to the body, only the axle moves up.
Posted on: 2006/5/1 17:16
yes boofhead I do i do have pics of the chevy w/lift is it okay to post them on here or would you like me to send them to you?
Posted on: 2006/5/2 7:04
as far as having the springs reset what do I need to tell the spring shop? Will springs from a sedan work, what about front springs? I think I could handle flipping the main leaf over my self if thats all I need to do. Is this a better option then the blocks? Thanks Dodgeman for the reminder on the ride quality, I always seem to forget about that untill its to late
Posted on: 2006/5/2 7:07
(1) 2 3 »
