AIRBAGS ???
Quite a regular
Hi dose anyone know bout airbags from australia for a 1200 ute, how much? can i install em? what else is needed??? and even if i should just drop it with blocks nd springs and what height???
Posted on: 2006/5/4 9:36
Re: AIRBAGS ???
From Christchurch NZ
I think disco stu put airbags in his ute.
Posted on: 2006/5/4 9:40
Forced Induction!
Re: AIRBAGS ???
From adelaide
ohhh f#$K yeah! Bag it!!! that would look mad as! i think you could pik up a whole kit and installed for 2000-2500, that is how much my mate got quoted for his car.but that seems pretty steep so just do your research, if you did it yourself like u sed it would b waay less. cant wait to see it if you do, post sum pics for us all to see.
Posted on: 2006/5/4 12:17
Re: AIRBAGS ???
From Brisbane, Narangba
There are no real kits to suit any car really. Most parts are of a standard size and are just adapted so thats not a problem. The only problem i can see is with the leaf springs. The bag goes in the same place the coil does in a 4link rear.
To do it so that it actually drops low you would have to cut the tray and basically fabricate it so that the mount point is higher than the body so when dropped the body drops over the rear axle and not on it other wise youll only go as low as until the diff hits the floor.
Posted on: 2006/5/4 12:51
Re: AIRBAGS ???
From bend oregon
For a little info check www.airride.com maybe this will help
Posted on: 2006/5/4 14:24
Re: AIRBAGS ???
yeah mannn do it do it ....... like this
there's a few other pics, a blue ute, and showing the tray ...... but f@#ked if i know how to find them ??????????????
Posted on: 2006/5/4 14:42
Re: AIRBAGS ???
From Burbank, CA
to fully drop it you will be doing a lot of work. anything less might be done easier ways.
Posted on: 2006/5/4 15:14
|||\ 81 KPB310 /|||
Re: AIRBAGS ???
From Gold Coast Australia
I reckon all those japanese 1000's and 1200's look sweet with airbags.
I will however tell you to steer clear of airbagit.com as a friend of mine purchased a setup from them for his rodeo, and had noting but problems from day 1. The air lines were all cut way too short and the so called made to measure chassis insert wasn't even in the same postcode of lining up. So after many hours of rectification, it was all in only to discover that some valves had corroded, and were loosing air.
Im with Scotty01, you must show us some photos when your done 'cause it will look cool as.
Posted on: 2006/5/4 15:41
SR20DET Sunny for sale, click me for details
Re: AIRBAGS ???
From Melbourne, Victoria
i got quoted $7-8000 drive in drive out conversion.
i wouldnt recommend diy. lots of work to do (cut n paste chassis) and pretty easy to stuff up and write off ya ride.
Posted on: 2006/5/5 2:18
Re: AIRBAGS ???
From Lismore, NSW
Hell yeah, those 1200's look sweet, i would say go for it...
Posted on: 2006/5/5 3:48
