quickie
Quite a regular
From Townsville, Land Down Under
Just a quick question to all you datto fans...has anyone actually managed to install a sub in a 1200 ute??? If so how did you do it? The only way i could think (without wrecking the ute) would be to put one in the doors or take the centre console out and put an 8 inch there or something.
Posted on: 2003/1/12 12:57
yes please
From Melbourne, Australia
i dont have a ute but...
i was thinking, have you seen the parcel shelf some 1200s have under the glove box? if not go look at one
maybe you could take that out and bolt in a box which had say a 10 inch woofer just pointing down towards passengers feet, wouldnt be a huge box but maybe enough for some 10 inches and not exactly prime positioning, but how desperate are you for bass
found pic of my car showing parcel tray (in coupe)
parcel tray to be replaced with doof doof
Posted on: 2003/1/12 13:07
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: quickie
From Sydney, Australia
The only way is to get some of those "Bass-Engines" They work great. And take up only a little space. They work by making the whole car vibrate...This is bad if you have lots of rust holes filled with body filler (Bog).
You might be cruising and parts of the car will fall off
The alternative is to make up a a tonnau cover out of water-proof chipboard, and use water-proof polypropylene subs. Then you'll have some "phat" BASS.
Chris
Posted on: 2003/1/12 13:21
Re: quickie
From Brisbane
what about cutting the wall bettween the two seats in the ute just to fit the SUB and have the box in the tray? (water proof of course)
would it get RWC? how hard to do?
Posted on: 2003/1/12 15:17
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Re: quickie
From nsw,AUSTRALIA
or put a false floor in and put some subs in there thats wat my frends unkle did
Posted on: 2003/1/13 1:53
A14+1200 ute=dirty pants
Re: quickie
Quite a regular
From Pretoria - South Africa
What I've tried was to build boxes for 6x9 's and had them under my seats, worked fine until you really want to pump base then the air-space under the seats just is'nt enough and the base get distorted.
Posted on: 2003/1/13 8:04
Re: quickie
From Brisbane
why didnt you put the 6x9s in the doors?
Posted on: 2003/1/13 11:25
bounce
sorry to bunny the thread but does anyone look at the subject on the replying posts, i.e. did anyone notice the heading i put on the second post in this thread?
just curious as i went to another forum and didnt know what people were talking about sometimes as they put key info in that heading, seems a bit odd to me
Posted on: 2003/1/13 12:47
1200 Coupe Rallycar
Re: bounce
Quite a regular
Now I am confused, are we still trying to fit the sub in the ute?
Posted on: 2003/1/13 14:04
Re: bounce
From Arlington, TX, USA
Not sure if they have them down under, but an SAS Bazooka tube would likely be a good fit? The small 6.5" model is small enough to go behind the seat and it makes plenty of bass. Heck, if it'll fit behind the seat you could probably install 2.
Posted on: 2003/1/13 23:01
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
