Re: Lowering rear end of a 1200 coupe
From nsw,AUSTRALIA
when every one says coupe do they mean coupe as in the one that is like soup or the other way with the a sound on the end
Posted on: 2002/12/8 0:02
A14+1200 ute=dirty pants
Mate it is really either way, coop or coop-aye
Posted on: 2002/12/8 0:41
From Melbourne, Australia
chicken coop for me
Posted on: 2002/12/8 1:27
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Auckland N.Z
mmm.... coop.
Posted on: 2002/12/8 11:43
From Canberra, Australia
So - What is the deal with reverse eye rear leaves?
Cos my car sits right at the front. But just seems too high at the back. Wanted to drop it like 1-2 inches...
Is it just standard leaves with the main one turned over?
I take it that this can't be done at home?
You go to a supsension place to do this?
Posted on: 2003/3/8 14:30
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
From Sydney, Australia
Just get some lowering blocks. You could do that at home.
Reverse Eye'd spring would be better.
The reverse eyed springs is where they flatten out the loops at the ends and then reverse the loop the other way. IT drops the car 2 inches. This can only be done by a suspension place.
Posted on: 2003/3/8 21:43
From Pakistan
what if only one eye of the spring is reversed(the one closer to the ground compared to the other eye)!, other is left as is so car gets a little lower while still making both ends of leaf more parallel to the ground.
what do u guys think?
good idea or not
barpk
Posted on: 2003/3/8 22:12
STRONG IS STRONGEST ALONE. PERIOD
From Chewton Victoria Australia (near Bendigo)
How much does something like that cost?
Posted on: 2003/3/9 10:12
1970 Datsun KB10
"only he who goes too far,
knows how far he can go"
Isn't it those guys who drive British sporty cars that say "coo-pay" and "saloon"? Here we generally "coop" and "sedan".
In Japan it is literally written クーペ (kuupe as in "ku-peh", two syllables) but I'm not sure if it is pronounced as one syllable or not.
Posted on: 2003/3/9 19:31
Barpk,
Doing just one will mean it gets lowered only half as much.
I can't seen any real advantages in doing this. Changing the shackle lengths could be done to equalise the difference. Otherwise your diff will be no longer point forwards. This might put additional load on your rear universal joint, causing problems.
Lumix,
As for the cost. I bought mine 2nd hand from a fella in Newcastle. I reconditioned them myself (New nylon sliding bushes), and sold them to Mikali. I figure that he's already resold them.
Cheers,
Chris
Posted on: 2003/3/9 20:27
« 1 2 (3)
