Leaking water
From Canberra, Australia
Car leaks water. Not from engine or anything.
But when it rains, the inside of the car gets wet. There is one leak out the back which I believe is the seal on the rear window.
There is another leak up front that comes out on the driver side only... Seems to be from kick panel...
Anyone know anything about what this might be?
Happen to anyone else?
:Edit: driver side = Right hand side
Posted on: 2003/3/27 15:14
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: Leaking water
From Fort Worth, Texas, USA
Probably what has happened is the rubber around the windscreen has shrunk. This so common on Datsuns, I'm surprised it hasn't come up before! Either replace the rubber, or squirt some black silicone into the gap and trim the excess so it doesn't look bad. Well, I guess a third option would be wear rubber shoes.
Posted on: 2003/3/27 17:00
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
Re: Leaking water
Quite a regular
From wellington, new zealand
from wot (little ) i kno is that if the windscrren has ever been out, then there may hav been a lack of silicon when it was replaced, this happen to a lot of mk 1 and mk2 GOtina owners, who hav had 2 replace their windscreens, can be remedied also by re-doing the whole process, but the rubber MUST b free of all old sealant and dust, to ensure a decent seal is achieved, but it has been 5 yrs since i did my 120y, and DIMLIGHTS option is way f#$%^n easier!
Posted on: 2003/3/27 22:43
UFO Unidentifiable Falling Object
me soo sick, head hurts
Re: Leaking water
From Brisbane, Australia
could also be the common rust under the cowl problem
Posted on: 2003/3/28 7:56
Re: Leaking water
From Melbourne, Australia
thats what i was thinking, my new coupe has water in the passenger corner and my bro-in-law could never find a leak in the window or anything, i reckon theres a tiny rust hole down there somewhere
Posted on: 2003/3/28 8:00
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Leaking water
Cowl? is this the bit where air is taken in for the fans and such? if so, how do I get to it?
The stuff seems to be coming in from under the kick panel from what I can tell (It just rained here tonight)...
HAven't really been worrying about it cos it ahsn't really rained here for like 8 months...
Posted on: 2003/3/28 10:14
Re: Leaking water
From Brisbane Australia
nearly all my 1200's had the same problem but it was on the passenger side and it was the cowl rusting away we have just modified my two door by adding bigger drain holes in the side of the rail so all the crap will flow out.
grab a torch and a small screwdriver and have a pick at the seam sealer up under the dash if there is any rust you will soon find it.
Posted on: 2003/3/28 22:52
Re: Leaking water
i missunderstood what you were talking about when you said cowl
i just went and high pressure cleaned the car and found water running behind the kick panel from up where you were talking about
if you stick your head in the footwell and look up in the corner there is some silicone type stuff where the two metals meet, i had water dripping out here
not to mention the rear window seal, boot seal and both quarter windows on the front doors, oh and i think one of the back wing windows was leaking too
no wonder all the carpet is rotten! and the car stinks
Posted on: 2003/3/29 4:12
1200 Coupe Rallycar
Re: Leaking water
This pretty much sounds like what is happening to me...
yeah, so how did you fix this?
Ummm did you fix this?
How would I fix this...
It's too dark now to go outside in the rain and get into some hard core yoga to see up there...
Adn my back is sore anyway...
And I may or may not be drunk...
neither confirm nor deny...
Posted on: 2003/3/29 12:20
Re: Leaking water
id go with drunk
but anyway, i only discovered it this morning so yeah i havent formed a plan of attack yet, im picking you could see me running round the car with a silicon gun trying to fill up every orrifice i can find
Posted on: 2003/3/29 16:30
1200 Coupe Rallycar
