coilovers for sale!!!
From Melbourne Vic
Well its time to sell these finally as i'm upgrading again. I have decided to sell the complete strut but keep the shock. It will come with a koni red adjustable shock if needed. Fit under 13 inch wheels, all done maybe a few thousand km's.
shortened 240k strut body 255 lb springs, brand new s13 cusco camber tops, slotted 253 mm dba disks, ferodo race pads twin spot sumitomo calipers and a partridge in a pear tree.
there may be some machining of the hat required to fit the different koni's but its a very simple job.
$680 with the koni red's
Posted on: 2008/2/15 21:03
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Re: coilovers for sale!!!
From penrith,sydney,aus
will you post??
Posted on: 2008/2/15 22:43
2 door 1200 sedan project l20b stroker
From The garage, NZ
i cant remember, did you have these in your 1600 or 1200??
Posted on: 2008/2/15 22:48
From brisbane, qld
Sounds lke a bargain! Someone should snap these up pretty quick.
Posted on: 2008/2/16 0:22
From s.e.qld
hi champ am keen on these... if you can post let me know... also can i get your number to have a chat about these... cheers
Posted on: 2008/2/16 3:52
From Adelaide
Bargin.
Posted on: 2008/2/16 10:22
if only I had a 1200 great price!!!
Posted on: 2008/2/16 12:49
From Melbourne Vic
Hi fellas, sorry for the no reply...
someone will need to confirm this but i am fairly sure if you run the stanza or sunny lower control arm etc these will bolt up. you may have to enlarge the three hole at the top of the strut tower also. boofhead is running these camber tops in his 1200
the setup cost me over double that and i made it so i could run 13 inch wheels and tyres for datnats as i had aquired some semi slicks in that size. the ride is sensational, not harsh at all i guess a 1200 may differ slightly to my 1600
i will drop them at any post office or courier at the buyer's expense. pm me your number if you have any more questions and i'll be happy to help.
cheers
leigh
Posted on: 2008/2/17 1:38
any cheaper with out cusco tops, surely some one will want them as i have already
Posted on: 2008/2/17 4:58
From Tamworth , NSW
id be interested in the strut tops
Posted on: 2008/2/17 5:33
