theoritically, what times would a ute with 300hp run?
Quite a regular
theoritically, what times would a ute with 300hp run? and would it be streetable
Posted on: 2008/4/16 13:23
Re: theoritically, what times would a ute with 300hp run?
From south coast nsw
geez mate theres alot of of factors to take into acount there maybe b a bit more specific.id say too fast for u, and me.
Posted on: 2008/4/16 15:08
From sydney
As to whether it would be streetable, that depends on the donk, if it needs to be really cammy and reving its tits off to make 300hp it might make for a painful daily driver but if its doing it in a relaxed fashion like say a 426 Hemi would then it would be a joy on the street, I dont know what times a 700kg car would do with 300hp but it would be beating everything else on the road off at the traffic lights.
Posted on: 2008/4/16 15:25
That's really a bit of a vague question, so here's a couple to have a think about.
Is this a dedicated showpiece with detuned blown 426 hemi?
Is it to be powered by a turbo'd & blown A12 running on nitro instead?
Other engine?
Is it some rotted old hulk with 12" tyres & a bad engine instalation, or something in between?
Is it intended to be used as a commuter?
I know you said 'driveable' but is it intended to be legal?
Will you be running slicks at the track.
What will be the final weight?
Auto, manual, or special drag transmission?
Leaf spring suspension or four link?
Ladder bars?
Wheelie bars?
Other?
Can you 'drive' [as in, experienced drag race driver]
Do you know anything about cars at all?
Is this a big budget project, or shoestring?
Can you build this car in a halfway decent workshop, or will it be a backyard job with crescent wrench & fenceing wire?
The answers to these & many other questions will determine what kind of performance you can expect from the finished product, but the question, as asked, really is unanswerable.
Posted on: 2008/4/16 16:05
Love your Datsun.
Treat it well.
10.87 second quarter mile, tops, if it has well sorted suspension, tires, etc and a good driver. Or you could do worse.
Posted on: 2008/4/16 17:17
From Melbourne ( West )
There is a mathematical tool called a Moroso Calculator (could be available online)??? - not sure.
But you put in all of the info available to you and it will give you a 'perfect scenario' quater mile time.
Engine builders use them in the reverse to work out how much power and tourque they will need from an engine to get a (????)- kg car down the quater in (??) seconds.
Posted on: 2008/4/16 21:08
'78 Ute CA18det Project
No matter where you go... There you are
From Christchurch NZ
Posted on: 2008/4/17 8:24
Forced Induction!
From Bendigo, Victoria, Australia.
need some fat tyres and a few sandbags to hold traction!!!
Posted on: 2008/4/17 11:22
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
Quite a regular
Its obvious tou are just pissin in the wind otherwise you would have clarified yourself to all the responses you got...
Posted on: 2008/4/18 6:40
From BRISBANE, QLD
isn't always just a pissing comp when it comes to guessed power figures and speculation on times...rather then actual times and real power figures??
i want my coupe to run deep into the 11's when it is making 320plus
Posted on: 2008/4/18 8:41
Back after a long absence and looking to build a beast starting with a 1974 1200 sedan
(1) 2 3 »
