A15 twin webers, hard to tune?
From Sydney
hi, i have an A15 in my morris minor and was looking at getting twin webers, but i herd that it was hard to keep them in tune.
any information on this would be greatly appreciated
~n87
Posted on: 2008/7/29 5:55
Re: A15 twin webers, hard to tune?
From Wamboin near ACT(canberra)
i have twin 45mm webers on my a15, I get it tuned up by a professional shop as i have heard it is really hard 2 do by yourself, i get it dyno tuned. i get it tuned around every 6 months
Posted on: 2008/7/29 7:27
From Sydney
I dont think they are any harder to tune than any other carb. An understanding on how weber's work will be the big advantage. Personnaly I think 45's on a street A15 is an overkill. 40's would be better suited or even a single sidedraught.
Saying that however, it is a black art to extract every last bit of power out of an engine on a pair of twins.
Posted on: 2008/7/29 7:39
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Sydney
well its for my play around weekend car so i would like it to have a fair amount of power (its fun seeing the face of the people in the doof doof cars when i go speeding past them off the line
but i guess what im trying to ask is that if you have one carbie and it gets slightly out, its not that notacable, but with two and they get slightly out does it make that much of a difference?
thanks for the quick response
Posted on: 2008/7/29 8:06
From Melbourne, Oz
If you buying weber's and ther not tuned for your size motor then the first tune witch includes jet's and venturies and what not then it's quite expensive. But once tuned correctly probly once a year would surfice on a road car..
Posted on: 2008/7/29 8:12
"I hav achieved wood"
From NZ
Seems to be a common misconception that sidedrafts somehow go out of tune over time.
Once they're set up properly (Dyno to ensure correct jets etc) there's not much to go out of tune unless the idle mixture or balance is fiddled with or engine spec is changed.
A Dyno is not necessary to re-set idle mixture and balance - just need someone who knows what they're doing.
Posted on: 2008/7/29 12:11
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
Carby doctor off lewis rd in knox victoria is a ledgend with pretty much any carby. Just ask grail3.
Posted on: 2008/7/29 12:21
put up where you live mate, so people can recommend a good place to go to
Posted on: 2008/7/29 21:18
From Sydney
NSW central coast, about an hour out of sydney
Posted on: 2008/7/29 23:17
That's right. They are tuned the same way the stock Hitachi is: with jet changes and adjustment screws.
So
- Yes it is difficult
- No, not any more difficult than any other carburetor
Synchronizing twin carbs gives an additional step -- but this is needed wether it is factory Twin hitachis, Twin Webers or any other brand of duals...
Posted on: 2008/7/29 23:22
