Re: L-series into a 1000
From Armidale N.S.W
Yeah Though it doesnt sound that nice when i read it like that.
Posted on: 2008/11/9 11:23
73 1200 wagon SOLD
From Geelong, Vic
cant really take much out of a CA sump to get it sitting lower due to the crank girdle...it sits pretty close to the bottom of the sump
if you really want to do it right id be looking away from the common nissan engines and finding something newer and lighter that can be adapted to a RWD gearbox...but might not fit in with the plan of being cheap
Posted on: 2008/11/9 11:25
From brisbane
I think it was D that suggested either a Suzuki Vitara or Suzuki Swidt GTi motor with a Sierra gearbox as a light and compact option.
Matty
Posted on: 2008/11/9 11:30
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From port elliot , SA
i got ofered a E15 outta my mates ETturbo pulsar for my 1K any one no how that would go apparently its the same mount pattern as the A15
Posted on: 2008/11/9 12:07
From Geelong, Vic
yeah matty thats the one i was thinking of, wasnt it supposed to be lighter than an A series or very close to the weight of an A series
Posted on: 2008/11/9 12:14
From Armidale N.S.W
Based on mates with swift GTI's they tend to go hard for about the first 5000k's then go down hill from there. Unless they were built with go fast bits i guess. Then we wouldn't be talking budget builds.
Posted on: 2008/11/9 12:21
73 1200 wagon SOLD
From Auckland N.Z
I'm always loath to suggest non-nissan options but what about a 4AGE, they are cheep, light, compact and if you banged a set of 40mm webbers on the side they are super simple to set up... (Oh and are grunty little, rev happy motors)
Posted on: 2008/11/9 16:40
From Armidale N.S.W
Yeah got a 4AGE in a car sittin here Can sell ya the whole car if ya want. So you would have a front cut just need a RWD box etc for conversion.
Posted on: 2008/11/9 21:35
73 1200 wagon SOLD
From Sydney Australia
I am going to fiddle with the GTI engine in my K, I have one lying around and you can buy sierra gearboxes for $200. Will let you know how it goes. You can guy cheap second hand go fast bits at redlinegti.com
Cheers!
Posted on: 2008/11/9 23:14
I think you better get your facts straight as you sound the same as a rotary motor myth maker.
Every suzuki gti owner I know and have spoken to have taken their GTI motors the famous g13b to beyond 300,000klms with abuse for all its life and never complained about performance.
Ive had several with over 250,000 and they perform like high spec sports cars.
The GTI car is ranked in the top ten most important modern cars of the century.
After market parts are available like you would not believe.
Gonzales in Puerto Rico has taken records for years in the FWD class with standard internals and 30-40psi boost and a local in QLD has taken a 1190cc version to almost 400hp for a slower ET but to illustrate the mighty G series potential.
Weight for a block and head is just on 60kg and 15kg more for ancillaries in the g16. Pikes peak was won many times with twin G series engined beasts also.
When I compared all the motors out there the G series is still being produced on the 1.6 Carry wagon, the sohc 16v head flows more than the twin cam g13b, they are used in light aircraft extensively, they have no VVT or other complex timing systems, they are all pressure die cast alloy and hardly ever blow head gaskets in with extreme boost with standard head gaskets and small and compact.
The only other engine that comes close but has vvt and virtually no performance parts available is the younger brother suzuki J20 from the vitara 2 liter.
A distant 3rd but Nissan/Renault is the Mr20DE followed by QR20de. These Nissan motors are taller but worth while pursuing for the all Nissan aspect. I particularly like the QR20De as it has so many aftermarket bits from Wolfe in the States.
Posted on: 2008/11/9 23:39
« 1 (2) 3 4 5 6 »
