Re: Rear Panhard in 1200 sedan
From ACT Aus
from what i've found people are concerned with it binding the springs but i quote
For a suspension travel of 3 inches and a horizontal Panhard rod of 30 inches (centre to centre) there will be a maximum lateral misalignment of 0.9 mm.
This lateral misalignment could be more than halved if you set the panhard rod to sit at rest below horizontal so through the 3 inches of suspension travel 1.5 is done below horiz and 1.5 above horiz.
so this makes sense to me, i mean i know for sure that my diff moves across more than 1mm so a panhard is just restricting this movement ttto 1mm which is one of the reasons for it isn't it?
Posted on: 2009/1/19 8:10
From gold coast QLD.
My opinion(for what it's worth)build yourself a nice Watts Linkage.They work nicely in all applications and suspension travel(see road car)is not the issue that it is with a panhard bar.
Posted on: 2009/1/19 9:30
From ACT Aus
bert could you please tell me what the main issue with them is? is it just the binding or what?
Posted on: 2009/1/19 9:47
Yeah mate thats about it.If you have very minor suspension travel,as in a race car there fine but having said that i've ripped one out of it's mounting bracket at P/Island several years ago....too much travel.
Thats why the Watts Linkage is so much better(but harder to make)and changing rear roll centres is a snap if engineered into the design.
I would'nt use a panhard rod on a road car with leaf springs,i don't think there needed.
Posted on: 2009/1/19 9:55
From Melbourne, Oz
what if you were to slightly triangleate an anti tramp tipe set up? would reduce lateral movement somewhat? and would still alow relativly "full" movement...
Posted on: 2009/1/19 10:51
"I hav achieved wood"
From Christchurch
Maybe I should give a little bit more insight into my setup.
As I said its a road car that I want to use for track days and sprints. Its been lowered approx 3" in the rear with JTS springs a commodore borgwarner diff and i'll be running bilsteins. It is unfinshed yet but I will also be using tramp rods running off the spring plates similar to caltrac's and would like to run a panhard rod because i am pretty sure the bigger diff will move round alot more than the wee baby diff that came out of it. I also like the idea of the lower roll center. It also has limited travel with the with the JTS springs and bilsteins with approx 5-6 inches travel from full droop to full bump. I don't see binding being an issue with that much travel, if it was an issue rubber bushes could be used
Perhaps I wasn't very clear, I was more interested to see pictures of how people have mounted there's I wasn't asking the whys and what for's. I have already done theresearch on panhard rods etc. It does however seem that not a lot of people run them even with the bigger diff's hence why my searching didn't really bring up any usefull picture/info on there mounting
I had thought of a watt linkage too but I think it looks hard enough to get a panhard in the back there let alone everything required for a watts.
Posted on: 2009/1/19 22:03
From Sydney, Australia
I put a panhard rod in my sedan.
rear suspension link
I made the rod adjustable length, because at different ride heights the panhard rod pulls to one side.
That's because in a 1200 sedan, there's not a lot of room back there to get the perfect mounting points for the rod to attach to. Also a problem to leave enough space for the exhaust to snake through.
I barely squeeze 2.5inch pipe through the monkey bars that are my rear suspension.
Of course with my trailing arms I had to run either panhard or watts. I still hope to put a watts linkage on some day. I have the falcon bw78 bits ready for the day.
I had a gemini panhard rod on leaf springs too, in my 1200 project that ran JTS rear springs and a ute diff. I needed it to locate the diff because of my passion for fat/sticky 205/60 series tyres (14 inch) that stuck better than the cornering G's with more than 2 people in the car.
Posted on: 2009/1/20 0:33
From Christchurch
Thanks, I had forgotten about your car shoey. I had a scroll through the photo's but could really see the body mount end of the panhard. (the end i'm most interested in)
I will also be able to make my panhard longer too because i wont have coil overs in the way so the sideways movement will be less
Posted on: 2009/1/20 1:18
How so? the diff doesn't move around unless the tires are slipping...
Posted on: 2009/1/20 4:32
From ACT Aus
by ddgonzal on 2009/1/20 14:32:23
i think it's more the car moving around on the diff. i've got 205 semis on the back with a torana diff and i can feel a fair bit of side to side movement of the car on the diff, especially in quick left rights. i think that because the diff is so heavy it tends to stay put if that makes sense?
Posted on: 2009/1/20 7:06
« 1 (2) 3 4 »
