Wubbits, that is right, I read it and I never went back to regular oils in my jeep and I have not started to use synthetic in my Datsuns untill the good stuf comes in(headers,cam twins), the synthetic bonds to the gaskets, and the regular oils do not, if anybody uses synthetic oils, you CAN NOT go back to regular oils.
A way to witness synthetics are way better, I witnessed it, is to drive hard your engine on your regular oil, and then, when ready to spend that extra money(well worth it) in oils forever(you can not go back ), try driving hard , you will see that your engine drives cooler, much cooler, recovers faster(after a fast run, go to iddle or slow driving, it will cool off faster) and that is a sure measure that your oil is more efficient.
Nicholas, Mobil, here in US (in S A should be the same if you have , as mentioned , Mobil brand,)... we have Mobil synthetic oil, as well as Mobil 1/2 synthetic(known as blend) and regular Mobil oils. I use Mobil synthetic in my jeep, and it works excelent.If there is Mobil synthetic in S A , check it out, must be good. You can call Mobil corp representatives in S A and ask if it is the same synthetic oil sold by Mobil in US. Here it has excelent reputation.
Jaime._______________________
