intake setup on thou..
From perth western australia
hey guys just wanting to know if i was to have a pod filter at the front of the car into a tube to a thinner box to fit under the bonnet of my thou coupe would it full on restrict airflow or what?? the box will only be allowed to be like 4 inches maximum.. the tube is what 2.5 i just have to keep her all under the bonnet to pass over the pits... dont know if anyone else has tried yet thats all... and i dont wanna have to cut another bonnet up
cheers guys help is much appreciated.
joel
Posted on: 2009/5/17 14:31
Re: intake setup on thou..
4" is plenty for maximum air flow. No worries.
Posted on: 2009/5/17 17:14
From Perth WA
is the motor a12 or a 14/15, if its a14/15 u wont have 4 inches, less than 3.
Posted on: 2009/5/18 4:00
its an a12.. but it sits like 2 inches from the bonnet... it is like hell high.
Posted on: 2009/5/18 15:13
From Freo
should be able to get the stock air cleaner in with A 12..
it's got the wrong mounts...
Posted on: 2009/5/19 2:19
A15 PSI Project Motor
'72 CB750k,
they are the mounts that jordy put on it... i dont mind having it out the bonnet.. i am thinking of putting a scoop of some sort on it so it will look a little better... or custom making something to fit underneath the bonnet.
Posted on: 2009/5/19 13:54
From perth airport
the mounts are 1000 rubber with aproxx 2inch angle line has per the the wiki and has per the everyone elce
the stock a12 carbie clears but with the factory airbox it hit the bonnet
Posted on: 2009/5/19 14:58
perth airport parking
Datsun 1200 ute A14
alright so what do i do... go and get some papers saying i need it covered up... just cover it up orrrr get papers saying im allowed a air filter hanging out...
Posted on: 2009/5/21 14:23
From Melbourne Vic
I have an airbox that i modified originally from a vanette i think that basically lets you attatch a pipe for a pod. i could take some pics so you could copy it or you could buy it if you get stuck
Posted on: 2009/5/21 15:18
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From pooraka,,adelaide
yer man go the vanette ont that should fit sweet
if not other option is make/find a foam one iv done that before
Posted on: 2009/5/22 0:21
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
