Revs on A Series Motors
From Cape Town, South Africa
I've done so many searches on this site, but still can't find the answers.
So let me ask a few relevant questions.
What is A series Motors able to rev in standard, lightly modified, race modified trim?
What is good modifications that can be done to increase maximum revs?
Balancing, light weight rotational parts etc, please add to this.
Please add your Axx series and the amount the bugger revs, some detail on modifications. This could be quite interesting.
Posted on: 2009/6/12 12:31
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
Re: Revs on A Series Motors
A14 Sub
A12 GX Head
Dual SU Carbs
A12 Flywheel modified to 5.8kg
Limited to 7000rpm
Seems to get valve bounce at 7100rpm.
And this sucks, a lot, hoping to fix it thru this post
Remember my father saying this thing should do more than that. Could it be worn out valve springs or am I so far off, I need to sit in the corner and punished for being stupid.
Posted on: 2009/6/12 12:34
www.race-tech.co.za
From Perth WA AUS
Get new double valve springs for a start, as for the rest???
And check that your clutch & flywheel will take more revs than 7000rpm or you might miss your feet when they are gone! :)
Posted on: 2009/6/12 12:57
Datsun 1200 2Dr sedan.
From Darwin NT
ive heard the speedway boys wind the motors out upto 14,000 rpm
but these are fully blown methanol mosnters with a huge diet on internals
Posted on: 2009/6/12 12:59
current project 4x4 patrol...
From brisbane
The 1000 coupe I bought from Bert has a balanced A12 with ported A15 oval port head.
Will rev to 8500rpm but peak power is around 6500rpm so anything beyond 7000rpm is pointless.
Matty
Posted on: 2009/6/12 13:41
Edited by matty on 2009/6/12 14:46:17
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Matty, is it possible to list what parts is in this A12
Posted on: 2009/6/12 14:02
www.race-tech.co.za
From brisbane
Hi mate
A brief run down on the specs are:
Oversize pistons
Balanced internals
Ported A15 oval port head with heavy duty valve springs
Custom camshaft
45mm side draught Weber
Aftermarket and modified intake manifold
Custom extractors and exhaust
Bert will be able to answer any other questions I expect.
Cheers Matty
Posted on: 2009/6/12 14:50
Stock A12 revs to about 6500
Stock A12GX has dual valves springs, and redline at 6600 -- what can it rev to?
Posted on: 2009/6/12 18:46
From Newscastle, Australia
stock...6000-6200 rpm..limited by sinlge valve springs and ponit type ign.
modified with head work, 10:1 comp, 98 ron, double GX valve springs and elect ign, 7500-8000.
full race with injection or twin 45's knife edged crank forgies Elf fuel big ports dry sump etc etc.
10000rpm tops
14k isnt quite right Jeff taylor does competion speedway engines in Sydney and 10k is about it. Even then you need to change the crank mains bolts every 2 races as they stretch they are under so much load.
Although id love to hear an A series rev to that, I wont in my lifetime.
Posted on: 2009/6/13 0:38
Dont die wondering.....
Not too shy to talk
The Cherry featured in the Paul Davies' book produced 109bhp at 10,000 RPM.
Lightened, balanced crank.
Lightened, balanced conrods.
Lightened, balanced flywheel.
Heavily ported head.
Double valve springs.
Larger valves.
Race Camshaft.
Electronic fuel injection.
4 into 1 exhaust.
Not bad for an A10, proved to be one the most successful racing Datsuns of that time.
Posted on: 2009/6/13 1:01
(1) 2 3 »
