Re: problems with a maddat sway bar
From Albany, Perth Australia
basically you dicked it hehehe well put up a pic tomorrow and we can see whats wrong
Posted on: 2009/9/23 14:37
1200 Smerf Mobile
From perth airport
no way did i do any thing wrong i think its not ment to be ran with the ajstable lca's even tho i got the hole lot of maddat :/
Posted on: 2009/9/23 14:41
perth airport parking
Datsun 1200 ute A14
From Adelaide
Hey Jordan, Did it pop out when you were doing up the bottom bolt, or when you were trying to locate the link end to the control arm?
How far are the adjustable control arms wound out?
Oh and did you follow the instructions???
If you have done nothing wrong it may be a fault with the link, let me know and i will send a new set over to you.
Cheers Scott
Posted on: 2009/9/24 0:03
From perth airport
LCA's, casrter arms and sway bar was all fitted. then @ a later date i have went to put in the struts and bolt'd the top in then holding the strut with one hand and the lca with the other i pushed down on the LCA slightly to get the strut in then on the drivers side same again and the sway bar link poped out .
the adjustable control arms are about 80% wound out and im shore this is why the link failed ?
yes and had it sitting the way the pic's on your instructions said to have it :)
im more worried that its not designed to run camber and it will keep happening ??
ill load some pic's up tonight n see wat ya think :)
cheers
Posted on: 2009/9/24 2:35
Datsun 1200 ute A14
From Adelaide
Sounds like you may have a faulty one, i'll send a couple more.
I have had tha same set up on my ute, and race every month with no problems, and i run 3.2 neg camber.
Posted on: 2009/9/24 4:23
From perth airport
cheers Scott
i thought i would of had around that much camber with just my camber tops ? have you tryed it with the lca's max'd out ?
cheers
Posted on: 2009/9/24 5:07
Datsun 1200 ute A14
From perth airport
here's the lil bugger
Posted on: 2009/9/24 8:32
Datsun 1200 ute A14
From Adelaide
If you have the arms wound out a fair way, you may have to drill a new hole in the control arms. The link ends need to be close to 90 deg. from the swaybar when the car is on its wheels.
I sent a new pair friday, but i think that it is not the problem.
Scott
Posted on: 2009/9/26 1:48
I noticed it when I was last around Jordy, I thaught u were still puttin it together so I didn't say anything. Did u know then?
Edit:it not tar
Posted on: 2009/9/26 5:11
Edited by bailz on 2009/9/26 7:52:41
From perth airport
I noticed tar ??
Posted on: 2009/9/26 5:22
Datsun 1200 ute A14
« 1 (2)
