Problem with electrical drain
From Atlanta, Georgia
So I've been fighting a parasitic drain since I bought the car(1981 B210.) I can't seem to find any evidence of a drain other then a dead battery in the morning. I've pulled all the fuses, disconnected all the lights, and I'm still getting a slight drain. Just enough to kill the battery by morning. Theres no evidence of any wires grounding, and I've gone over just about everything with a meter and found nothing. Any suggestions?
Posted on: 2010/2/9 22:33
Re: Problem with electrical drain
From Adelaide
Have you checked the battery completely isolated, they self discharge when they're worn out, the sulfate separates and shorts the plates or something like that. Try disconnecting it, charging it and leaving it over night, then check the voltage.
Posted on: 2010/2/9 23:42
Yeah, thats been done multiple times. The battery is fine as long as its left unhooked when the car isn't being run.
Posted on: 2010/2/10 0:12
Here's how to find the problem.
Turn off the kar
Remove the negative battery cable.
Take you ammeter and connect it to the NEG battery post and to the NEG battery cable
Note how may milliamps are being used.
Pull a fuse
Check the ammeter
Pull another fuse
Check the ammeter
When it stop showing current, it is something on that fuse circuit.
Posted on: 2010/2/10 3:23
new battery? fly me over and i will have a lool
seeing as u have had it for a while, is it only every now and then? surely u havent stored the car for 20 odd years?
Posted on: 2010/2/10 10:56
From hastings,vic
could be a faulty diode in the alternator or reg
try disconnecting it, then see if that helps
Posted on: 2010/2/10 11:38
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
Thanks for the recommendations. I'll go check now and get back to you all.
Posted on: 2010/2/10 20:58
1981 Datsun B310
1973 Honda CB175 K7 Cafe
ddgonzal- Checked it. I still had a drain after removing all fuses
bailz- I just bought the car about 2 weeks ago. I'm the third owner. The original owner drove it until it stopped running. The guy I got it from only had it a few months. Put some new parts in in and $550 later, shes mine.
tommo- your the winner! that was the drain. However, I didn't disconnect the positive or negative cable. I unplugged the plug on the back above the ground.
Anyone know what it's for? It's causing a pretty substantial drain. I'm not an alternator, guy so I'm not sure if this is a stupid question.
Posted on: 2010/2/10 21:41
Edited by metalmonkey47 on 2010/2/11 0:14:16
1981 Datsun B310
How many milliamps current did it draw? Alternator will draw some by design but not enough to drain your battery for many days.
That plug is for the alternator Signal and Lamp wire (LS). But both are fused, so if you pull the lamp fuse and the alternator fuse it shouldn't occur.
Tommmo was refering the big red/white wire on the altnernator which is unfused, and it a diode protected form draining your battery.
Replace the alternator to test. I have one you can borrow, i'm in the Eastgate area.
Posted on: 2010/2/11 0:58
With the harness connected it draws .88 miliamps. Disconnecting the alternator wire doesn't help solving the drain issue. The alternator started making a bit of noise because it seems as if a bearing is going out so I just may replace it anyways. I appreciate th offer though.
Posted on: 2010/2/11 1:52
