Re: crossmembers from maddat 13b
From Melbourne AUS
it doesnt effect drive or power, you just need to adjust your diff pinion angle to suit. otherwise you'll have chronic universal joint failure among other things
Posted on: 2010/4/25 14:01
1973 B110 A12
From Sydney
would a maddat 1600 13bt engine fiting kit fit a 1200 ute? or are the chassis very much larger
Posted on: 2010/4/25 14:40
From Melbourne AUS
would be very different i would think
Posted on: 2010/4/25 14:46
1973 B110 A12
From Sydney
but at four degress every conversion would have this problem ? unless the gearbox tunnel is small and aims down wards?
jpg  !BiM04q!Bmk~$(KGrHqUOKjMEsnr2+M8!BLNpPs8b(!~~_12.jpg (38.75 KB)
12811_4bd457a488983.jpg 500X375 px
Posted on: 2010/4/25 15:55
From Sydney
my transplant
jpg  !BiM0jNgCGk~$(KGrHqEOKj0Esls1Pr5RBLNpNmfkt!~~_12.jpg (35.21 KB)
12811_4bd458a388c80.jpg 500X375 px
jpg  !BiM0z3gBmk~$(KGrHqMOKj0EsIKF+WYcBLNpPM!sG!~~_12.jpg (38.91 KB)
12811_4bd458c7856b6.jpg 500X375 px
Posted on: 2010/4/25 15:59
From Melbourne AUS
looks like a series 2/3 gearbox like im using
the angle seems to be more of a problem with rotaries into 1200's, i havent completed a 4 cyl conversion so i cant really say for sure
Posted on: 2010/4/26 1:09
1973 B110 A12
From Sydney
so far so good just need a light weight tail sharft to connect to my 9 inch?
Posted on: 2010/4/26 1:27
i think rotors sit on an angle anyway don't they? on my old datsun the weber intake manifold sat level but the motor would be on a slight angle
Posted on: 2010/4/26 4:43
From Sydney
i guess i will see soon enough
Posted on: 2010/4/26 5:13
From Geelong, Vic
yeah most engines sit on an angle pointing down towards the gearbox, as lethal_john said, the carby base sits flat. thats usually a good way to figure out if where you have your engine is good or not
thats how i decided where the final placement of the engine would be on both the L series conversions ive done. obviously need to make sure the car is sitting prety level too
Posted on: 2010/4/26 13:01
« 1 (2) 3 »
