Anyone used cut down (2.5mm)A14 pisons on an A15 crank
From South-Africa,Pretoria
Hey guys Im thinking of using A14 pistons in my A15, would removing 2.5mm from the A14 piston render it fragile and weak? there would be about 3.5 left from the top ring to the top of the crown?
Posted on: 2010/4/30 12:27
1993 Nissan Bakkie - Rebuilding A15
www.spitronics.co.za
Keep it OldSchool, keep it Datsun
Some can afford the legends, other try to revive them.
Re: Anyone used cut down (2.5mm)A14 pisons on an A15 crank
From Perth
Not recommended
Posted on: 2010/4/30 15:00
From Melbourne Vic
yeah i have had the same thought. why not recommended? isn't the top ring in the same spot?
Posted on: 2010/4/30 15:18
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From mandurah
cos they could burn realy easy thats why they made them so thick so that they dont get too hot and get holes blown in them
Posted on: 2010/4/30 15:29
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Sydney
In my experience, its not so much an issue of burning holes through the top but rather there is significant material removed off the top so that the cross sectional area between the top ring land and the piston crown is small enough to increase the chances off failure. However it will work, but for how long is the question.
cheers
benny
Posted on: 2010/4/30 23:17
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Newcastle nsw
Im doin it in my engine soon. I reckon itll leave enough meat and ill let ya know the comp ratio with a h89 head after doin so.
Posted on: 2010/5/3 7:49
i have decided to do so awell, wont know if i dont try. will keep you posted.
Posted on: 2010/5/4 12:01
From Gawler, Sth Aust
Would be interesting to hear how this works out. It sounds plausible.
How much meat is there to take off?
Posted on: 2010/5/4 12:25
72 B110 A14
71 B110 A12a (Parts)
06 380 VRX
From Freo
why not use A15 pistons???
Posted on: 2010/5/4 12:44
A15 PSI Project Motor
'72 CB750k,
From Newcastle nsw
a14 pistons have a larger distance from the gudgeon pin to the crown, therefor if u use an a14 piston in an a15, it protrudes out the top of the block. machine 2.5mm off the top of the piston and u end up with pretty much a flat top piston. However the top ring is close to the crown. i machined down an old piston to show what i am talking bout.
jpg  c 001.jpg (67.63 KB)
12703_4be27847392c9.jpg 820X615 px
jpg  c 002.jpg (78.75 KB)
12703_4be27852d6755.jpg 820X615 px
jpg  c 003.jpg (73.68 KB)
12703_4be2785f0afd0.jpg 820X615 px
Posted on: 2010/5/6 9:05
(1) 2 3 »
