Re: Datsun Mechanic's List
Yeah Curtis that's a good un. Lowmion pull the fuel line while you're cranking the engine and put it into a little container check that the fuel is flowing well. There is a ml/minute rating in the manual. But if you see a fair bit coming out then that's okay (not a drizzle or a drip).
Just knock all the variables out of the equation and go from there.
Fuel- tick
Spark- tick
Compression- tick
etc etc etc
Posted on: 2010/7/19 10:46
The fuel filter is always full of petrol and through the carby window I can see the float level which doesn't drop at high revs, although I can't see it under load of course, but will blow the line out before the fuel filter to tank just in case :)
Edit
I also rewired the ignition to separate high amp switch's as the old ignition switch fell apart - to make sure I wasn't losing voltage there.
Posted on: 2010/7/19 10:51
Luck is what happens when Preparation meets Opportunity.....
From Bendigo, Victoria
Sorry I didn't get back to you the other week, daughter works in a bank and it got robbed so got tied up for a while. If you could get down to Bendigo about one and a half hours away I think I would have everything you need. Got a running a12 you could pull the carby off and try or the whole engine if required. Probably have most of the other parts you need to. Cheers Ivan.
Posted on: 2010/7/19 11:00
Thankyou Ivan, I'll do that - would the Sat 31st July or Sun 1st August be suitable?
Sorry for your daughters grief - you told me about that when we spoke, so I didnt want to intrude.
Posted on: 2010/7/19 11:09
That shouldn't be a problem keep in touch when it gets close to the time. I've still got your phone no. Ivan.
Posted on: 2010/7/19 11:21
A very good friend has given me this carby telling me it'll need to be rebuilt and possibly re-jetted. Its a 26/27 Holley, and he gave me a brand new adapter plate for it as well.
(He also told me my points we just about missing all together, so they're being replaced tomorrow)
Is it as easy as swapping over the cable linkage to it from my old one to attach the accelerator cable?
Who would you send it to, to have it totally rebuilt - I can easily put the gasket carby kit in it but I want new butterfly pins etc which is beyond me.
Thankyou in advance - and Ivan I'm still planning on traveling up to Bendigo this w/end for bits :)
jpg  Image071.jpg (21.79 KB)
13171_4c4c1400357ae.jpg 320X240 px
jpg  Image072.jpg (22.46 KB)
13171_4c4c1419946fc.jpg 320X240 px
jpg  Image073.jpg (22.85 KB)
13171_4c4c143083943.jpg 320X240 px
Posted on: 2010/7/25 11:47
From hastings,vic
i might be 3 hours away
but will beable to fix/replace your problem(wich is now taking time to fix)
and no fix no charge
in it for the love not the money
if it was for money i would be broke
when u get over it give me a ring
it will be somthing basic!!!
tommo
Posted on: 2010/7/25 13:52
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
On the Cortina Mk1 forum the have these recommended carby repairer's and the associated notes, have any of you used any of these repairers?
Is it recommended to take car and carby to them so it can be jettted using the dyno? Or not?
Victoria
Thornbury carburettor service
763 High st Thornbury 3071
03 9480 2108
no tuning just lots of parts and spares
and reco ing
Power play (the old datrally)
plenty of experience in tuning webers
dyno tuning
simon and mike
10 Charlton Ave Cheltenham Vic 3192
(03) 9584-7373
03 9584 7373
can be expensive tho
B&M Fuel systems
3 Albert Street
Richmond, 3121
Victoria, Australia
Ph (03) 9429 3510
they also have a dyno
Posted on: 2010/7/25 13:57
From hastings,vic
i would fix current problem
before creating more! spending more $$
then move on
a series are very simple.
dyno not needed unless jetting carby.
Posted on: 2010/7/25 14:08
From Geelong, Vic
do you know the costs involved with getting the carby fully rebuilt and jetted to suit the engine...coz it sure as hell aint cheap
Posted on: 2010/7/25 14:09
« 1 2 (3) 4 »
