clutch issues!!
From Sydney
hey guys im having a few problems with my clutches at the moment ive fried a few different combinations and set ups but they are all slipping... my a14 engine is pushing out 89.9hp at the wheels and clutches are just slipping... any idea of a good cluch set up for my car cheers..
Posted on: 2010/9/29 22:20
Re: clutch issues!!
From Sydney
Is it running the std 180mm clutch. By chance is the clutch cable been over adjusted?. Is the flywheel flat smooth and clean of oil residue.
Posted on: 2010/9/30 3:25
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: clutch issues!!
yes, agreed. Slipping means it is not adjusted correctly.
There must be play:
* At the pedal
and
* At the release lever
Posted on: 2010/9/30 3:50
Re: clutch issues!!
From Sydney
yeah guys its all been installed cleanly and properly im a qualified mechanic and yeahh.. umm at its got a 180b pressure plate with watever clutch suits this and slips like crazy and is adjusted properly
Posted on: 2010/9/30 9:47
Re: clutch issues!!
what box is it and what thrust bearing u using as there are a few differant length thrusts
Posted on: 2010/9/30 9:49
Car free
Re: clutch issues!!
If thats a pic of your little yellow car. I think its a beast! Got nothing to ad with your clutch problems tho... sorry
Posted on: 2010/9/30 9:56
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
Re: clutch issues!!
From Perth WA AUS
Is it adjusted for a 180b clutch or a 1200 clutch?
Posted on: 2010/9/30 13:24
Datsun 1200 2Dr sedan.
Re: clutch issues!!
From Ringwood, Melbourne, AUS
Is there freeplay in the clutch cable/pedal?
What are the fingers on the pressure plate like? They should be flat when the pressure plate and friction disc is torqued down to the flywheel.
If they are sticking out a bit, the disc is too thin and it won't be clamping as much as it should.
If they are sticking in, the disc is too thick.
Posted on: 2010/9/30 13:33
Deano
Re: clutch issues!!
From Kuala Lumpur, Malaysia
me nubies got a question too...
my A15 is doing a 130hp on flywheel and im using stocked A15 clutch set and A12 5speed gearbox and its slipping too starting at 5000rpm to 8000rpm...
can anyone share with me what clutch set is good to modify or is there any just plug and play...
Posted on: 2010/9/30 20:58
Face Your Demons
Re: clutch issues!!
Your A15 may be putting out more torque than the stock clutch is designed for. But first verify that there is 5mm play at the clutch level coming out of the transmission. If there is no play, it can cause slipping.
Nismo sells a heavy duty clutch for A-series.
Posted on: 2010/10/1 3:37
