1200 sill panels
From Mudgee NSW Australia
Hi Guys Im replacing the drivers side sill panel on my 1200 as I found a bit of rust in there :( I replaced the passenger side 5 years ago its still good.
The answer Im after is the 1200 ute and 1200 coupe the same sill profile at the front near guard. I can no longer get drivers side sill genuine but can get 1200 ute genuine nissan for just over $100 Im 99% sure the only difference is in the length can anyone confirm this??
thanks in advance Andrew
Posted on: 2004/1/5 3:35
If In doubt run more BOOST
Re: 1200 sill panels
From Warwick, QLD
Hey andrew I know where you can get sills (non genuine) from. This is the place where I got mine from fit great
Sill Outers $35 code: RP168
Rear 1/4 $25 code: RP167
Contact
Craig Vayne
Sheetmetal Fabrication
41223921
He's up in QLD maryborough I think, cost $40 for a sill and rear quarter to be sent down.
Hope that helps
cheers
damo
Posted on: 2004/1/5 3:55
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Brisbane
does he make any other models?
I want some sills, lower door cover (its like a thin metal sheet kinda aluminum) and some chrome mouldings for my 240K
Posted on: 2004/1/5 4:12
Not too shy to talk
From Perth, Western Australia
ok, i'm stupid, where's the sill panel?
Posted on: 2004/1/5 6:15
i drive an old ladies car.
From Brisbane Australia
Under the door !!
Posted on: 2004/1/5 8:18
From GOLD COAST AUZ
Just go to a sheet metal shop with a cardboard template of shape(out side) and a bit more than you need,thats all i do at work.A few secs with a tape and press, all foldded up ready to weld in place.0.9mm is thick enough 1.2mm if you can not weld to well with a mig
Posted on: 2004/1/5 8:34
rather be a old fart than a young d##khead
From Canberra, Australia
Andrew
Youre right. The only difference is length, the ute sill is about 75mm shorter.
Posted on: 2004/1/5 8:43
Quite a regular
From Perth W.A
c.v. sheetmetal make sections for most datsuns and they fit perfectly too. ring him and ask for a price list or check out his website. i think it's www.craigvaynesheetmetal.com.au or something real close to it.
Posted on: 2004/1/6 3:51
From Townsville, QLD
thought, i'd look into this a little, since the previous owner has done the old bog treatment to both my sills, the whole length of the car. Lazy.
Anyway, here's the address for Craig Vayne: http://www.workin4u.com/rustpanels/
funny, this is the town i am from too, probably knew the guy once maybe?
rockon
Posted on: 2004/1/6 4:14
Fuel lines this week, turn the key by the weekend.....
From Brisbane
I had a quick look
its a bit expensive if its priced each
Posted on: 2004/1/6 5:26
