rwhp to run 10 second quarter
Quite a regular
From perth
Does anyone what rwhp i would need to run a 10 second quarter mile
Posted on: 2004/1/10 3:19
Re: rwhp to run 10 second quarter
Not too shy to talk
From Sunny Coast QLD
Wat car would help...
Posted on: 2004/1/10 3:30
From newcastle, NSW
don't worry about rwhp! if you want to run a 10 second pass you should be counting it in $$$$$$$$$$ not horses, FJ 20 worked should run below 10's
Posted on: 2004/1/10 3:37
From Arlington, TX, USA
Check out this website.
Figure a 1900lb curb weight (full tank of gas, 150-200lb driver, full interior 1200). To run a 10.8 @ 125mph, you would need at least 300whp. A 10.2 @ 135mph would require at least 360whp. Does that answer the question?
Posted on: 2004/1/10 4:21
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
From campbelltown (sydney) australia
it doesnt really answer the question because u must factor in the amount of drag the car is going to make, considering the shape and size of the car, there are many things, hp isnt the only consideration.
Posted on: 2004/1/10 5:12
Precisely why I said that was the minimum HP you would need.
His question is actually completely impossible to answer with any amount of accuracy. There are WAY too many other factors to consider, as you suggest.
Posted on: 2004/1/10 5:32
From Christchurch NZ
Here is a formula developed by Chryslers
drag racing program back in the 70s.
( wt\hp)x((mph-100)\400 +1)cube rooted
x5.5 =ET.
This assumes an optimized car and an optimizwd run down the strip. In other words , the shift points,gaering ,engine combination,and drive line components were properly chosen and matched and the car had the perfect amount of tire slip at the start.
Quoted from SA DESIGN How to install and use nitrous oxide injection systems for maximim horsepower.
ps I brought this book prior to seeing The Fast and the Tedious
So depending on how good your algebra is that may be some help
Posted on: 2004/1/10 7:12
Forced Induction!
Oh yeah , and try starting with about
ten grand to begin with
Posted on: 2004/1/10 7:14
Forced Induction!
From sutho shire
10g's didnt go very far on my project
try 25g's
Posted on: 2004/1/11 12:12
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
From Sydney, Australia
I'm being as innovative with my budget as possible, and These are average prices...mostly including doing the work yourself.
Lets say:
Engine+turbo: $6000
Paint: $4000
Exhaust $1000
Rubbers door/suspension: $1200
hoses/pipes: $500
shocks springs: $1000
Brakes $1500
Diff: $300
Electricals (relays etc): $500
ECU+ tuning: $2500
interior retrim (inc seats): $2000
Fuel system: $300
Intercooler + hoses: $1000
new glass: $500
new panels: $500
wheels/tires: $2000
1st yr rego/insurance/eng cert: $2000
$26,800
cost to maintain GF/wife: $2000
cost on brain for worrying about some d?ck stealing it: $10,000
See...it's REAL easy. I'll say it again..you'll still have only an "ok" car for this kind of money. You need to get "lucky" and find parts on the cheap to get out of it any better. And you need to become better at haggling on prices. Every dollar counts.
Chris
So next time you hear the term " Ground up rebuild"..please be impressed, because it's cost the guy twice as much for a 5% better result.
Posted on: 2004/1/11 13:30
