CAms, Cams, Cams...
From Auckland N.Z
Ive had a brief search and cant find any info on cams. What cam is best to fit in a a12? I have heard the a14/15 cam with a regrind is the best but Im not sure. I have access to both a stock a12 and a14 cam and I want to get one reground to sute my worked a12.
Help would be wonderful
Cheers
Quinn
Posted on: 2004/1/14 11:46
Re: CAms, Cams, Cams...
From Invercargill, New Zealand
Hi Quinn,
Call up Kelford Cams in Christchurch Kelfords - they've been grinding these for years and have all the info re: profiles. If you want something in the North Island then CSL(?) in Palmerston North are meant to be OK too but Kelfords are my first choice.
Cheers,
Ian.
Posted on: 2004/1/14 12:09
From Auckland N.Z
cheers teretonga
Im going to see Tony Marsh tomorrow and ask him. how much is it for a regrind at Kelford Cams?
Posted on: 2004/1/14 12:14
Around $120 rings a bell.
Posted on: 2004/1/14 12:16
From Auckland N.Z
how long do you reckon it would it take? Ive got a race it a week and a half.
to soon?
Posted on: 2004/1/14 12:24
Quinn
Even if you got it on friday, would you have enough time to rebuild the engine as well as RUN THE CAM IN.
I think the cam manufacturer / regrinder would tell you how long to run it at restricted RPM before you give it a flogging, but this may prove to be a limiting factor.
Chris
Posted on: 2004/1/14 12:55
Love your Datsun.
Treat it well.
From Perth, West Aussie
speaking of cam grinds... does anyone know what a good cam for my A15 would be? I got extractors with 2inch system and dgv weber.. Its in my 1000 wagon which will be used for towing my catamaran and running stuff around so I need a 'torquer' profile.. nothing lumpy , just enough to bring the afforementioned mods to life :) is there anybody in Perth that could do this also?
Posted on: 2004/1/14 14:08
From Auckland N.Z
Dodgeman I was not aware that one must run a cam in! I guess it makes sence. Oh well another race in a underpowered car. But it should be ok because Ive just installed Bilstiens and saughted out the rear springs (were to soft and low and kept bottoming out).
Posted on: 2004/1/15 6:07
Quite a regular
From Perth
shoom,
Try Ranch Automotive in osborne park.
My mates old man works there and they rebuilt, balanced and machined alot of stuff for me when i was building up my old escort.
They have a cam regrind department too.!
Posted on: 2004/1/15 6:20
1980 sunny std dreaming of ca18det
2000 CBR600F4
The cam manufacturer will provide the break-in instructions.
They used to be something like: use this special cam lube, and when you start the engine first time, run it at 2000rpm for 30 minutes -- do not let it idle.
Is this still the usual method?
Posted on: 2004/1/15 7:25
