Re: CAms, Cams, Cams...
The cam manufacturer will provide the break-in instructions.
They used to be something like: use this special cam lube, and when you start the engine first time, run it at 2000rpm for 30 minutes -- do not let it idle.
Is this still the usual method?
Posted on: 2004/1/15 7:25
Subject Poster Date
     CAms, Cams, Cams... Quinn 2004/1/14 11:46
       Re: CAms, Cams, Cams... teretonga 2004/1/14 12:09
         Re: CAms, Cams, Cams... Quinn 2004/1/14 12:14
           Re: CAms, Cams, Cams... teretonga 2004/1/14 12:16
             Re: CAms, Cams, Cams... Quinn 2004/1/14 12:24
               Re: CAms, Cams, Cams... Dodgeman 2004/1/14 12:55
                 Re: CAms, Cams, Cams... shoom 2004/1/14 14:08
                 Re: CAms, Cams, Cams... Quinn 2004/1/15 6:07
                   Re: CAms, Cams, Cams... chuck 2004/1/15 6:20
                     Re: CAms, Cams, Cams... ddgonzal 2004/1/15 7:25
                       Re: CAms, Cams, Cams... L18_B110 2004/1/15 8:15
                         Re: CAms, Cams, Cams... Quinn 2004/1/15 11:01
