barry's Datsun チェリー 120A FII Coupé '79
Hello
i'm barry, living in the netherlands and the last 2 years restoring my F10.
bought it looking like this
after driving a couple of months and doing some little things to the car
i've rented a big space to take the car apart, the old owner has done some damage to the car i would like to repair
after completely taking the car apart
it looked like this
after a lot of work, I've sprayed it in primer
after a lot of sanding, it was time to spray color on the car, was the first time for me.
but when i was done, it looked very nice. the color is from the '80s Renault alpine A32
after a little black spray of some items, it was time for clear lacquer
began to place everything back on the car
then we had to move to a new building. than the mood to work on the car disappeared :(
but piece by piece the car came done
16" borbet a wheels polished and sprayed white with 195-40/16 tires mounted on the car
i've got some original 12" and 13" alloy rims to, for the oldtimer events
the car is still missing the engine, because i had it tuned, but the dumbass tuner has taken 12 months to do it
got it begin november back from him in bits and pieces, now i have got the engine build up, new cilinderhead bolts are on the way from japan, then i can hook everything back up and start the engine, i hope
specs off the tuned engine are
cosworth pistons and rods
specially made camshaft 278 degrees inlet and 272 degrees outlet
machined head to make room for the pistons end get better flow ports
bigger valves
weber 32/36 carb
protronix ignition
and more
here some pics of the engine now
sprayed the engine in heat resistant metallic grey
alsmost completed engine
taped of the engine en mounted it back in the car
will keep you updated over the rest of the Restoration.
and more performance ideas will be very welcome
also wan't bigger front brakes, because 219mm is to small. :(
Posted on: 2010/12/11 20:52
Re: barry's Datsun チェリー 120A FII Coupé '79
today pickup some never been used 120Y rims
5J x 12" so i can change the tires from my original steel wheels to this one
after first sandblasting them, polishing all the metal and spray some bits new in color
Posted on: 2010/12/13 13:52
From Vanderbijlpark, South Africa
hi barry, your project is looking really good, especially the engine! what kind of compression ratio are you running with the pop up pistons?
Posted on: 2010/12/13 15:25
93' Nissan 1400 a15 60a (daily)
82' Datsun 1400 ute (sold)
73' Datsun 1200gx Coupe (sold)
i think about 12:1 ratio
if i remember good what the tunes said to me.
also with this ratio it was still possible to go for a turbo set-up, but thats a thing for next winter
also today, when i picked up the rims, looked for a '72 datsun 1200 in blue, needs some welding and a respray
but for 400 euro's , I'll probably do it. got an SR20DET lying around from an S14. so that would be a great next project.
Posted on: 2010/12/13 17:49
From Tasmania
Great looking car Barry seen a bit about it on the UK datsun owners site. Good to see another Cherry owner on here.
Posted on: 2010/12/13 17:58
Proud member of " The Tasmanian Datsun Owners Group"
and it runs, i'm very happy and it sounds like a V8 :D :D :D :D
http://www.youtube.com/watch?v=AH8HRrziUxg
Posted on: 2011/1/10 22:48
From Coondle, WA Australia
lokks the goods.
Nice work!
Posted on: 2011/1/10 23:32
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
here a quick pic, better ones are on the way
Posted on: 2011/1/24 10:31
From Melbourne, Australia
wow beautiful look!
Posted on: 2011/1/24 11:32
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
what a kool little jigga!
Posted on: 2011/1/24 11:50
