Re: Getting rid of the front leaf springs on a 1000
rito fair enough let me know if you organize anything in the way of a group buy i'd be very keen
Posted on: 2010/8/14 10:16
when I get my hands on an old shocker in the next week will try
and get to spiteri to see what he can do for us who r interested
Posted on: 2010/8/14 13:43
From Geelong, Vic
ive been looking here for coilovers to use in the back of my wagon.
possibly a little bit cheaper
wats the difference between the standard and gold series GAZ ones?
Posted on: 2010/8/14 14:05
Nick I always look at summitracing for their awesome products but
once you land a set of the right combo with springs theyll be
more expensive than the GAZ maybe?.
Great site for bits like tube A arms and shocker mount brackets
Edit: with the current exchange rate this is the time to get them
Posted on: 2010/8/14 14:29
Edited by D on 2011/4/11 1:43:49
bump
would like to get some of these coil over front shocks soon.
Anyone have a spare front shock for measurements?
Or Dunde1000 you if you can get Endosan or whoever owns the
cream kb1k on the link for a gaz part no?
http://babelfish.yahoo.com/translate_ ... =ja_en&btnTrUrl=Translate
here are the ones Ill probably need?
http://www.summitracing.com/parts/HAL-ALN5855P/?rtype=10
http://www.summitracing.com/parts/HAL-ALN3855P/?rtype=10
any ideas on spring tension to suit stock front end weight?
110lb, 130lbs or higher?
Posted on: 2011/4/11 1:45
I was actually goin to do this today if it stops raining, I've been looking at a bilstein coilover setup and think I might of found the right length shocks for standard and lowered
Do you know the proper way to measure a shock?
edit - not being smart but im not 100 percent sure where to measure from i can post up what i measure unless you want the shock i got
Posted on: 2011/4/11 3:48
Edited by lethal_john on 2011/4/11 8:50:17
From Sydney
Hey D, ive got a spare front shock, where do you want me to post it?
Posted on: 2011/4/11 4:11
Minisport was where I was heading. They said they'd prefer to have the car there so they can have a good look.
Posted on: 2011/4/11 4:51
pm sent Gav.
Chris Minisport would supply the Gaz brand from the UK. would be good also.
I reckon there is at least 12kg on that front spring if not more.
Posted on: 2011/4/11 6:08
here's the standard specs thanks to ash
http://www.datsun1000.com/PageView.asp?PageID=24
a 150lbs/in spring is close to standard a little bit stiffer(i think if my maths is correct)
Posted on: 2011/4/11 13:20
« 1 2 (3) 4 5 6 »
