WTB early a12 gx regrind or stock camshaft (front dizzie type)
Looking for an early a12 camshaft with a gx grind.
Nothing crazy as Im taking my a12 out for front/rear main
seal and sump gasket change and felt its time to do it.
It will hopefully be fed by a custom single su manifold with
1 1/2 or 1 3/4inch undecided yet and 4 into 1 headers.
Posted on: 2011/7/18 6:47
Re: WTB early a12 gx regrind or stock camshaft (front dizzie type)
From Coondle, WA Australia
That dude in the US was selling heaps of these. Cams, cranks, rods, lifters, amonsgts other stuff.
Havent heard from him in a while?
Posted on: 2011/7/18 13:46
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Freo
not stock GX stuff though Reuby...
Posted on: 2011/7/18 13:49
A15 PSI Project Motor
'72 CB750k,
Yes PJZ has some serious grinds, I can get the serious grinds locally but few have the stock and gx-type of mild grinds.
Posted on: 2011/7/18 14:32
From mandurah
why not use a late model cam?? ,the dizzy just runs off the oil pump gear ,and the cam will just have a spare gear where the dizzy would be on a late model a12
Posted on: 2011/7/18 14:35
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Freo
the 'spare' gear is where the fuel pump lives Estyre...
Posted on: 2011/7/19 1:16
'72 CB750k,
stocky will be fine too
Posted on: 2011/7/19 1:53
PJZ had several stock GX camshafts for sale.
Posted on: 2011/7/19 2:50
From mandurah
Oh ok ,sorry ,well if an SU is going on ,maybe convert to an electic fuel pump ?
Cheers
Posted on: 2011/7/19 5:06
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
Ill try and get a local one first.
Then Peter as the last gasp.
Ill even settle for a stock 1000 coupe one.
Posted on: 2011/7/19 12:28
