engine bogging down?
From vic
hi i was just wandering if someone could explain to me why my engine bogs down as soon as the secondary starts to open for few seconds then picks up fine?
i have tried size 135 and 150 jets in the secondary but dosnt change much so i left in the 150 for better highend power.
Thanks!
Posted on: 2011/11/26 3:08
Re: engine bogging down?
This is generally not a jetting problem, but usually caused by fitting the wrong size carburetor.
Are you using Hitachi DCG306? Which one?
Posted on: 2011/11/26 4:47
From Sydney
could be flooding while your at a constant speed so when u put your foot down it bogs downuntil it clears out.. my a14 had the same problem..
Posted on: 2011/11/26 6:09
From south coast nsw
yes more info needed, by the sounds of it id say the vtec is broken:]
Posted on: 2011/11/26 6:53
Posted on: 2011/11/26 8:44
From vic
hahaha vtec.
yes its a stock hitachi carburetor i was just testing to see if it was the secodarys by sticky taping a 5 cent coin onto the mecanical weight to make it open up slower and it made the bogging alot less but not 100%.
thanks
Posted on: 2011/11/26 12:33
From Ipswich, QLD
Have you checked your fuel pressure? Maybe pushing fuel past the needle somehow?
Posted on: 2011/11/26 12:37
From vic
yer its a new fuel pump was somthing around 2.5 or 3 psi
Posted on: 2011/11/26 15:10
what colour are the plugs?
1 more vtecyo ha
Posted on: 2011/11/26 16:28
From Snohomish, WA USA
Put the bigger jet in the primary. I had the same problem. I have 190 in primary 's and 160 in the secondary's. My car bogged off the start and then picked up. Solved it by putting the bigger jets in the primarys. I run two carbs.
Posted on: 2011/11/27 1:52
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
