Re: Datsun 1200 Rack and pinion
Not too shy to talk
From Melbourne, Australia
our autocross car now has a welded diff and its a bit unpredictable in the corners, ill leave the diff open on the datto until im ready to get a LSD or phantom grip. As for the steering box I will rebuild it and get a new draglink, thanks for all your help
Posted on: 2011/12/10 9:22
70 Datsun 1200 coupe Rally/Autocross car In the biuld
76 Toyota Corona MK2 Autocross car
From mandurah
ok spill the beans ,what the puck is a phantom ??
is it an lsd of some sort ,and i hear 250 dollars cash money ,that sounds like my kinda lsd !!
hasnt a trd lsd centre from an ae86 been used before ?
Posted on: 2011/12/10 15:37
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Phantom Grip is an inexpensive LSD that uses a spring-loaded plate instead of the usual clutch-pack.
Posted on: 2011/12/10 21:18
From Adelaide
Isn't the downside of Phantom Grip that it pushes against the diff gears? Sounds pretty agricultural to me. One of those Torsen centres by topgear would be the go, have to do a lot more overtime before I can buy one though.
Posted on: 2011/12/10 22:33
i put up my christmas tree and that pushes on the floor.... what's your point?
phantom grip is awesome for dirt and wet epecially and you don have to do oertime to afford oe, the only downside is they arnt geat with big power on grippy surfaces,
Posted on: 2011/12/10 23:15
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Don't most LSD types push against the side gears?
Lockers are different, but you don't want a locker for most types of driving.
Posted on: 2011/12/10 23:32
From Adelaide
I may not have read carefully enough how they work so more of a question. Do the two metal plates use the gears as a friction surface? Additional load on gear surfaces and bearings? Probably getting off topic.
Posted on: 2011/12/11 1:14
H190 are cheap and available so seems worthwhile
Posted on: 2011/12/11 7:50
Not too shy to talk
what is a H190 out of? Where could i find a place that sells phantom grip for H165 or H190?
Posted on: 2011/12/12 9:11
urvans, 720 utes, vanettes, datsun 1600 and S3 bluebirds to name a few, go back and see business already mentioned that does them
Posted on: 2011/12/12 9:57
« 1 2 (3) 4 »
