JE Piston part no. for A series?
From NZ
Hi - does anyone have a part number I can try for JE Pistons? I have damaged No.1 piston (JE) in my race engine but unfortunately haven't yet been able to ascertain the part no. (I purchased the engine second hand some years ago).
Pistons are:
Flat top, with valve reliefs
Bore 78mm
18mm piston pin (full floating/circlipped. Brass bush pressed into conrod)
1mm top ring/1.2mm 2nd ring/3 piece oil control ring
Engine is A12A FWIW
Any and all suggestions gratefully received!
Thanks
Posted on: 2012/8/5 12:17
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
Re: JE Piston part no. for A series?
From Ballarat Victoria
Im guessing they will be customs. You may have to send one to JE as a sample.
If you can find out the original purchaser, they may have an order no. that JE should have on file.
Otherwise try Peter Z from the US.
Good luck.
Posted on: 2012/8/5 12:37
VIC DYNO HIRE
From Las Vegas USA
You will either need the order/job number, from which the can make a new one or simply send them the damaged one. Email them they will be able to tell you.
Tom
Posted on: 2012/8/6 2:50
