Re: L series engines in a 1200
From Brisbane, Australia
There's really bugger all difference in on-road performance between an L16 and L18 in a 1200. I've had L16, L18, and L20 in my old 1200.
Posted on: 2012/12/2 23:40
Not too shy to talk
From Melbourne, Australia
Hi,
Dad and i put an L16 in our 1200 coupe rallycar, its standard with twin carbs and a stumpy 5speed.
We made bigger trans tunnel notched the x-member and got a aluminium radiator made and put the thermo fan on the other side of the radiator.
It has quite alot of power and goes like a rocket
Posted on: 2012/12/3 8:36
Good to hear. Put up some pics of your little rocket
Posted on: 2012/12/3 10:05
Mik just can't help himself.
Has anyone run an L14T? The twin carbed version from the excellent?
Posted on: 2012/12/3 11:05
got to be bigger than yours definately bigger than mine
Posted on: 2012/12/3 11:53
Not too shy to talk
here are some pics of our coupe
Posted on: 2012/12/7 8:01
Edited by Dat12OO on 2012/12/7 8:35:34
From Armidale N.S.W
Change the capital IMG to lower case img and you get this
Posted on: 2012/12/7 8:08
73 1200 wagon SOLD
From Geelong, Vic
the weight wasnt an issue in my sedan either, went round corners just as well as an A series 1200 with similar suspention setup. and the torque is where the difference is. going from driving a 1200 with a worked A12 to one with a standard l20b in it the different is amazing. the car actually starts moving before 5000rpm
you have to remember than an L series is usually going to be mounted lower and further back in a conversion than what an A series is standard
Posted on: 2012/12/8 2:16
From Logan, QLD
Just purchased a L20B to go into my rig in the next few months, cannot wait. It came with twin su's and I am not sure if I should stick with them or go twin DCOE's, I am thinking as this is the final conversion that I will be going with mild porting and a mild cam to make it fun, unless a stock L20B with twin su's is the business in a 1200.
I dunno how much more difficult a L20B crossmember will be to make compared to a ca18det, but I think my ca crossmember was spot on for engine position.
Heaps of this conversion I am really keen on having a play with.
Posted on: 2012/12/8 5:29
Pigdog swears CA is easier conversion in the size of the engine bay
Posted on: 2012/12/8 6:55
« 1 2 (3) 4 5 »
