Maddat brake booster questions
From Chipping norton sydney
Hey I brought a maddat brake booster to put into my datsun 1200 ute and the original brake pedal dosnt fit onto shaft cause the haft I to long what have people used any hep would b great cheers
Posted on: 2012/12/13 20:12
Re: Maddat brake booster questions
From stinking hot cairns
Did you buy the kit from maddat? Because he supplies the new break peddle
Posted on: 2012/12/13 20:21
Yeh mate brought the hole thing from him no pedal
Posted on: 2012/12/13 20:22
From Nyngan, nsw Australia
i never had any problem fitting over the pedal(as seen by pic), only thing i had to do was make a new hole for pin to hold it on....
Posted on: 2012/12/13 20:37
Edited by hotrocket on 2012/12/13 22:01:19
living is good,.....
From Armidale N.S.W
I bought the booster/clutch master bracket expecting it all to fit with 120y booster but i had no chance of it working without using the original spacer.
Posted on: 2012/12/13 21:13
73 1200 wagon SOLD
From SYDNEY,NSW
i had to do exactly what hotrocket has said.
Posted on: 2012/12/13 23:04
vouch points for PIGDOG J-Dat dats-me TRAV 40RST minitruckin 120fly DEMO 1200dat aidaniel matty discobob mick1200 cemax DATSKOOL - all have helped me out with parts...Thankyou
Do u have to adjust the rod cause srsly it's way to long and if I push the shaft in it would be pusshing the breaks on correct
Posted on: 2012/12/14 21:36
From Goulburn NSW
Hi fellas im pretty shore that the pedal u get with the kit is for the clutch.
Posted on: 2012/12/15 0:34
The peddle is for the clutch
The brake peddle hole does need relocating
The fitting instructions has all this info on it!
If your ever in doubt ring Scotty up in business hours as he is happy to help out with his products and is all over these types of questions! Iv bombarded him with small questions and he has done all he can to help.
Posted on: 2012/12/15 0:41
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
From Sydney
I would not adjust the push rod because it will be set with the right clearance to the master cylinder. I can see in the photo that the stop light switch is holding the pedal down, move it away from the pedal and then you should get plenty or extra room. Let me know how this goes
Posted on: 2012/12/15 1:23
