« 1 ... 8 9 10 (11) 12 13 14 ... 16 »
Re: Datsun Dyno and BBQ day 1st june. Ballarat
From Adelaide
Still hoping to get there at some stage but have just discovered some leaks in my shed roof in bad locations that I need to deal with asap....
Posted on: 2013/6/1 0:42
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Ive heard some results coming through slowly.
Will let the members post though.
Sounds like a good day shame I couldn't go. But hey kids are a commitment
Posted on: 2013/6/1 5:24
From Melbourne, Australia
Thanks Simon for putting the day on, good fun and impressive setup. I left after lunch to be a responsible parent
I got 85rwkw with stock ca, good to find out its running rich but also to see boost is dropping right off. 10psi at low revs drops to 6psi very early. Explains my lack of power up through the revs. Need to replace turbo but may play with boost t first
Claires mustard mobile churned put 44rwhp and 40 with air con on. Not bad from a15 auto with stock carb, but now I'm inspired to manual and carby upgrade
Posted on: 2013/6/1 7:27
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Cheltenham
Huge thanks to Simon for running the day and putting on the bbq for us all. Nice day, good cars and meet new people as well as getting to see Simons coupe on the dyno, i couldnt think if a better way to spend the day.
Was good that the weather held off all day as well, looking forward to getting back down there soon to see about a better tune for my ute now
Posted on: 2013/6/1 11:52
From Geelong, Vic
WINNER
mine made 130ish rwkw on the first run t about 8psi.
then we played with the boost a bit. think it was about 140 something at 10psi
then a max of 166rwkw at around 6000rpm with 12-13psi still sitting on .75 lambda
so it still seems well and truly safe. tha'ts with CA16 inlet cam, t28, front mount, 3inch exhaust, pod filter, custom turbo manifold, standard 370cc injectors and an ecu that may or may not me tuned for exhaust and pod filter
so a big thanks to simon for making the day happen, just unfortunate that the a12 at something like 25psi couldnt quite beat my power. came very close though
Posted on: 2013/6/1 13:50
From Geelong, Vic
oh and after i made simon spend a bit of time printing my graphs off i managed to lose them from off my dash on the way home....so that sucks
From Geelong, Vic
stupid internet connection making me post multiple times
Posted on: 2013/6/1 13:51
From MOOROODUC. Victoria
Great Day,
Actually put the ute on to see what it would do with a knackered transmission, also got a valued third opinion of it "It's had it". Picked up another Auto Trans on the way home that I bought off eBay so that will go it soon-ish.
Also good to put some faces to the forum names.
Posted on: 2013/6/1 22:44
What did the auto Cade make demacoz?
Posted on: 2013/6/1 23:41
Car free
From Adelaide
Yep, good to put some more faces to names, even if I was late and without the Datto.... Next time.
Posted on: 2013/6/1 23:58
