SPRING RATES RACE CAR
From Albury
Quick question for all the racers out there, What spring rates should I be running ?
Car is a Coupe Sports Sedan with a SR20det 5 link ,coilovers etc.
Currently running 350 lb fronts and 200 lb rears (no sway bar on back )and still tends to body roll. I know Chooie was running 400 lb fronts and was thinking of uppin them but seems a lot of spring for 850 kg.
What do you think ???
Posted on: 2013/11/15 21:59
Re: SPRING RATES RACE CAR
From Brisbane, Australia
is it a proper sport sedan with the engine recessed through the firewall? If so, the rear is probably too soft.
If you are running wide slicks ?? you'll need more spring rate than people runnning the usual ~195 semi slicks too.
Also depends alot on your roll centre heights.
Posted on: 2013/11/15 22:45
roll centre heights, weight ratio front to back and what weight does Choo have on his?
Posted on: 2013/11/16 1:05
lol there seems to be an echo in here...
Posted on: 2013/11/16 3:41
Sorry could only read Bobs query at the time as I was testing an iphone and took for ever to load in a store selling them. Gave up too slow too small for my eyes and fingers carry on
Posted on: 2013/11/17 11:59
