Locked H145.
From Christchurch NZ
I'm in the throws of fitting a locked H145 to the blown datto.
I know that it is a neanderthol cure for my traction woes,(so no lectures please) but I was wondering how much grunt/abuse it's likley to withstand before the inevitable?
It will only be in use till I can find an H165 head so I can build a phantom grip, But I'm busting to run it at the next drags, so my hans are tied.
Posted on: 2004/11/22 7:52
Forced Induction!
Re: Locked H145.
From Wellington New Zealand
Perhaps you could stage a lottery with everyone on the site having a guess at how long it will last. With the torque your engine is producing and your reputation for giving it heaps I reckon it might last 2 weeks
Posted on: 2004/11/22 7:56
1200 coupe 1400 GX 5 speed
1200 coupe LHD peripheral port 12A rotary.
1200 ute
Sunny 310 SGX.
Re: Locked H145.
I'm in. I'l give it three full-on launches before something breaks. Thats with good rubber, not 12" crossply's with 60lbs of air.
Posted on: 2004/11/22 8:03
Love your Datsun.
Treat it well.
Re: Locked H145.
Yeah, I'm a bit worried about the stageing. I've been given some old tyres off a formula ford, to help put the power down. I'll be pretty gutted if she blows before I get to post a time.
Posted on: 2004/11/22 8:10
Forced Induction!
Re: Locked H145.
I give it two days of moderate street driving (that's how long the H145 lasted behind my stock A15).
Posted on: 2004/11/22 8:23
Re: Locked H145.
From sydney australia
put me down for the first time you let the clutch out.it'll be the axles which let go , however.they step down where the splines
go into the centre.if you're lucky,you'll break both at the same time & the car won't take a voilent turn to the left or the right.wait til you find a h165 before welding it up.
Posted on: 2004/11/22 10:21
Re: Locked H145.
From Sydney , NSW
Whist I agree that H145 axles are like toothpicks !! - I ran a welded H145 in my coupe for a year without drama. Admittedly only behind an A14 but it was not treated kindly ...... While your car sounds a bit beyond the H145 capabilities, usually it is side stepping the clutch that causes problems. Shock loads will kill components long before the same force applied linearly.
If in doubt - go for the 29 spline H190
Cheers
Posted on: 2004/11/22 20:17
Re: Locked H145.
From sydney
I reckon if you really try you will be able to total the diff on the first launch.
Posted on: 2004/11/23 4:51
Re: Locked H145.
From Brisbane, Australia
is this your daily driver? If so I don't reckon you'll make it to the drags. low speed trundling around town/subarbia is hell on axles with locked diffs. I give it 3 days normal driving.
But if you're still running the 60a box, I reckon that will still be the first thing to scream "enough!" at the drags before the axles.
Posted on: 2004/11/23 6:33
Re: Locked H145.
No, it's not my everyday car. It's way to hard on fuel for that.
Unfortunatly, drag racing is very much about shock loading of the driveline, with a hard launch being half the battle. I think I'll be taking a tow rope to the track.
I guess time will tell.
Posted on: 2004/11/23 23:05
Forced Induction!
