4wd 1200
From melbourne
has anyone done a 4wd conversion on a 1200 coupe is it possible
Posted on: 2005/4/21 8:08
are ya ready or are ya GREDDY
Re: 4wd 1200
From Bris-Vegas
I saw a 1200 ute go for sale up here a couple of months back that was based around a Sierra chassis & engine, so it should be possible for a coupe.
Posted on: 2005/4/21 8:21
Re: 4wd 1200
From WA
do you mean an all wheel drive vehicle (ala WRX, EVO etc) or a 4WD coupe (landcruiser, sierra etc)
Posted on: 2005/4/21 8:33
Re: 4wd 1200
From Newscastle, Australia
yes I have seen the same ute in Narellan NSW based on a Suzuki.
if you want AWD for racing I would try and shoehorn an EVO 6 or 7 driveline into a coupe. They are sophisticated AWD systems and with the EVO motor would be potent.
Anything is possible and I have even seen a AWD system from a Nissan GTR shoehorned into a VL Calais.
Posted on: 2005/4/21 8:46
Dont die wondering.....
Re: 4wd 1200
What about using a GTiR Pulsar?? 4WD and SR20DET. Kill two birds with one stone!!!!
Posted on: 2005/4/21 12:03
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
Re: 4wd 1200
From Perth
East West engine design there
If you want to stick with North South you'd need to use the GTR box
I have done alittle research on this for my 1000 coupe
You need lots of patience and big wallet before you start
Posted on: 2005/4/21 12:11
Re: 4wd 1200
From Tasmania
Na just get two E10 Cherry engines and gboxs and bolt one in each end. You will have AWD and almost 2litres of engines.
If you was realy cleaver you could even have all wheel steering.
Posted on: 2005/4/21 15:00
Proud member of " The Tasmanian Datsun Owners Group"
Re: 4wd 1200
yeah but if u was smart u would know that would never work. because neither engine would ever run at the same RPM. which would cause a pull/push a effect. and actually slow the car down.
Posted on: 2005/4/21 15:18
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
Re: 4wd 1200
From Warburton vic
I have seenthe 2 engine thing used in a honda civic at royal melbourne show. It was 2 fronts joind at the middle. 2 clownes where driving it & they could break it i half & drive it & drive it away from each other & they did grouse dounuts it was cool
Posted on: 2005/4/21 15:40
Re: 4wd 1200
From Central Vic
If your serious about this have a good hard look at some pics of a 720 ute setup
this would be a small nissan based system that could be applied
the physical size of the frount diff combo will be the strugell
the frount end of a A series powered pulsar might suplly some struts and drive shafts
how to get the transfer case in a 1200 tunnel would be a amazing design process
Posted on: 2005/4/21 16:18
