Swap idea: small aluminum V8
[url=http://srd.yahoo.com/goo/SHO+V8/3/T=1029818550/F=e76609241019b061fddad3994823a681/*http://www.mercurycapri.com/projectrsx/v8sho/teardown.html]Ford Taurus SHO V8[/url] 96-99
60 degree angle between banks
3.4-liter 32-valve DOHC V8
235 horsepower at 6100 rpm
230 foot-pounds of torque at 4800 rpm
Cast in the Windsor plant, assembled by Yamaha. Head design by Yamaha. Block design by Ford (just like the SHO V6).
The block is similar to the Ford Duratec 2.5 litre V6. bellhousing is Duratech and Zetech pattern (think German Ford 2.8 V6).
Posted on: 2002/8/20 5:31
Re: Swap idea: small aluminum V8
From Stone Age somewhere in U.S.A.
why not just use a VG30DETT out of a 90+ 300ZX, 300 hp and it keeps it ALL Nissan?
btw, the n/a version is 222 hp.
Posted on: 2002/8/20 6:07
From Christchurch New Zealand
that would make for one hell of a datto
i know you all want to stay nissan but anyway how about a BDA all alloy 2ltr
Posted on: 2002/8/20 6:10
From Sydney, Australia
The 60degrees and sohc should help it fit :)
That's the problem with the VG30DETT..it only just fits in the 300zx engine bay.
The vh45 etc are cool nissan V8s but parts are too expensive to keep it going.
The Lexus V8 would be ok, they fit nicely in MX5 miatas.
I don't need these kind of ideas at this point in my rebuild I'm having enough trouble getting it finished Although the registration hassles make it impossible here in Sydney.
Chris
Posted on: 2002/8/20 7:00
From Kyabram vic, aust,
How about a small iorn V8 like a windsor.
You can get alloy heads and a heap of other bits to make em go, check out the 289 windsor in my datsun 1200 sedan, through the section on go the dattos 1200 in the web links you'd be supprised how much room there is in there for a ford V8 in there
Posted on: 2002/8/20 13:36
The Ford 3.4 V8 might have some advantages over a Ford 5.0/302:
- All aluminum (including block), so should be lighter -- for a roadgoing car this is an advantage for good handling.
- Windsor V8s are narrow, but the 60 degree V8 should be even narrower (room for a turbo?)
I was thinking about the Rover/Buick alumnimum V8 -- but it's quite heavy for a 3.5 liter engine.
The Ford 5.0 weighs only about 450 lbs (about 50 lbs lighter than the lauded GM chevy smallblock), but I haven't seen any alloy blocks for 5.0s.
Posted on: 2002/8/20 22:21
the VG30DE(tt) came in more than just the Z car. believe it or not, it will fit, I have seen them in 510's and 1200's.
it looks bigger than it really is because the Z32 (300ZX) enging compartment is so small.
Posted on: 2002/8/21 5:26
From Tassie, Australia
Zoom magazine did a conversion a while back of a VG30 into a Chev Corvette. Thoe old 350 V8 was stuffed and the owner dicided to go for a newer motor. They reckoned the 350 V8 was smaller than the V6, this was because the V6 has all the plastic and piping hanging off it.
Posted on: 2002/8/21 5:36
From BC Canada
So, my question is, why stop at a V-8, how 'bout a W-16 in the old lb-110?
http://www.lambocars.com/related/bugatti2.htm
Posted on: 2002/8/21 6:36
From Melbourne, Australia
is there anywhere you can find out the weight of various motors cause when people say "aluminium whatever" im not really convinced (no offence anyone) that this means its a lot lighter, id just like to see some figures
Posted on: 2002/8/21 8:49
