split exhaust question
From brisbane
I have a CA powered 1200 ute with a 3" exhaust that is giving me ground clearance issues. The exhaust only ever hits in one spot where the flange that joins the dump pipe to the main exhaust is located. This is roughly a third of the way along the chassis.I have been toying with the idea of cutting the dump pipe closer to the front of the car and running twin 2" pipes a bit closer to the floor where I currently have clearance issues and then joining them back to the original 3" exhaust before the diff. Has anyone tried something like this before? Does anyone see any problems that I may not have thought of with this idea?
Thanks Matty
Posted on: 2006/1/19 3:53
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Re: split exhaust question
From Melbourne AUS
hey matty, perhaps you could run a twin 2" all the way through for something different.. and have 2 outlets 1 on either side of the car?
i personally wouldnt know of any disadvantages by splitting the exhaust and joining it back up.. i would think any loss of flow would be minimal..
i'd like to see some pics of your CA ute? are there any on the web that you could point me towards?
Posted on: 2006/1/19 4:25
1973 B110 A12
From Ipswich,QLD
Ok so the flange scraps , have you got a exhaust hanger connected to the flange most exhausts hang and scrap some times due to the fact the hangers are put in the wrong place or have used the old ones instead of refitting new ones
Posted on: 2006/1/19 5:49
From brisbane
Thanks for the replies.
I would rather keep the single 3" from the diff onwards as I don't want to buy new mufflers etc.
There are currently only a couple of photos of my ute on the Queensland Raceway site but that's it. I now have a digi camera so I will post some up when I can.
The exhaust has already been modified for more clearance but I would like more if possible. It's not a hanger issue just a big pipe under a low car issue hence the split pipe idea. I simply can't get anymore room with a 3" diameter pipe.
Posted on: 2006/1/19 6:30
I think I recall ca18det_man having twin pipes for this reason. I think there is even pics. He dont seem to have any drawbacks.
"Note- I only recall - might be wrong"
Posted on: 2006/1/19 7:18
From Tamworth, NSW
i have seen a twin in twin out muffler box.
Posted on: 2006/1/19 9:51
From Sydney, Australia
There is a certain area under the car where you shouldn't have a low point in the exhaust. My exhaust is 3 inch, and never bottoms out.
The cat converter must be as tight up to the body as possible.
Have someone stand perpendicular to a speed hump that frequently gives you trouble. Drive over it at a speed you normally would, and have them mentally (or digital photograph) the point where the car bottoms out on the speed hump. Once idenfied, make sure that part of the car has it's exhaust bits as snug to the body as possible.
Using more exhaust hangers stabilises the exhaust, and stops it from drooping when going over speed humps also. Hanging 3 inch on the standard hangers is a bad idea.
Getting stiffer front springs is also a good way to reduce the spring compression at slow speed.
Cheers,
Chris
twins is too heavy..unless it's titanium.
Posted on: 2006/1/19 10:25
From Townsville NQ
if it's the flange that does it, can you move the flange a foot or so either direction? If you don't have a split dump, could the flange be moved to the bottom of the engine bay for instance? That way the exhaust can still be pulled apart & you don't need to screw around making a twin system.
Posted on: 2006/1/19 10:34
From brisbane
I have considered having the flange relocated but this will still only give me a very small amount of extra clearance. I would really like 15 - 20mm more ground clearance.
Chris - would 3 feet of 3" pipe really be alot lighter than the same length in the smaller diameter?
Thanks again for the replies
Matty
Posted on: 2006/1/19 10:50
Lets do the maths.
CSA = cross sectional area.
3inches = 76.2mm
CSA = pi x R^2 = 4560 mm^2
For 2 equivalent pipes = CSA / 2
2280 = pi x R ^2
R^2 = 2280 / pi
R = sqrt (2280 / pi)
D = 2 x R
D = 53.87mm = 2.12 inch (2 and 1/8inch)
So you'd want to use 2 x 2.25 inch.
Steel density = 7850 kg/m3
= 7.85 g/cm3
Standard exhaust wall thickness = 1.5mm
So for 3 foot of 3inch vs. 3 foot of 2 x 2.25inch weight..
3inch
Circumference = pi x D
3inch x 3 foot x 1.5mm thickness
Standardised to cm to make formula easier.
7.62 x pi x 91.44 x 0.15 = cubic volume of the steel in that length of pipe
Mass in grams = 328.24 cm^3 X 7.85
= 2577.5grams = 2.577kgs
2.25 inch x 2
2x (2.25 inch) x 3 foot x 1.5mm thickness
2 x 5.387 x pi x 91.44 x 0.15 = cubic volume of the steel in that length of pipe
Mass in grams = 464.25^3 X 7.85
= 3644.4grams = 3.644kgs
An extra Kilo.. Talk about doing it the hard way...but I didn't have to leave my computer or bourbon and coke
Posted on: 2006/1/19 13:01
