FJ20e into 1200, anyone ever done this?
I've got a FJ20e. I was going to put it in my gazelle, but have gone off that idea.
Have recently taken a liking to 1200's.
Has anyone on this site ever installed one in a 1200 sedan (or know of anyone)?
Mainly want to know the hardest part of the conversion. e.g. does steering need mods? booster?
I understand I would probably be looking at custom gbox tunnel, reversed crossmember (or sump)
Any input appreciated.
Cheers
Martin
Posted on: 2006/2/4 10:47
Re: FJ20e into 1200, anyone ever done this?
From Bendigo, Victoria, Australia.
yes, its been done. there was a ute for sale last week on here.
it was a FJ20ET.
i would ask why an FJ? a SR has a lot more potential and a wider aftermarket following than the old FJ. also lighter and smaller.
for that litle bit extra price up front, u can have an engine that will cost u less in the long run.
the sump should be ok.
the tranny tunnel will need a new hole for the shifter (shifter more towards handbrake on FJ 'box)
have a look at Maddat they make kits for the FJ into 510. perhaps a rough sketch for ur 1200 can be drawn from what they offer.
cheers and let us know how u get on
Posted on: 2006/2/5 2:30
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From sutho shire
my mate up in qld is just installing his fj20et into his 1200 ute,
its a very tight fit i think u will find that u will have 2 postition the motor in the bay after cutting existing a12 mounts off 2 work out sump clearances and if the steering needs 2 be moved ect i would cut out firewall 2 allow little more work area around the bell housing ect as its tight as with a ca18 . im 99% sure u cannot buy a off the shelf kit for the fj20 conersion.
Posted on: 2006/2/5 6:48
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
From Brisbane, Queensland
http://www.fj20.com/
A few examples on that site mate. mostly FJ20ET, but i'm sure its not much different
Posted on: 2006/2/5 8:41
Is there a known reason why Nissan never called it a FJ20DET?
Posted on: 2006/2/5 9:13
Beacause its a single cam head. The D stands for double overhead cam.
D = Double overhead cam
E = Injected
T = Turbo
TT = Twin Turbo
Posted on: 2006/2/5 10:27
From south australia
i was sure fj20s are twin cam
Posted on: 2006/2/5 10:30
just checked out fj20,com they are twin cam heads
Posted on: 2006/2/5 10:36
From Melbourne AUS
i havent heard of any steering mods being necessary...
booster is a matter of preference to require less pedal effort when braking.. although i dont think you would fit a booster in with the fj unless it was remotely mounted..
most difficult mods would be transmission tunnel, and getting your brake master/clutch to fit in whilst clearing the fj's intake..
i dont know much about the fj conversion but i have seen some fj 1200's with remote brake master cylinders.. and others with custom or alternate intake plenums used...
good luck
Posted on: 2006/2/5 10:42
1973 B110 A12
E = Injected
T = Turbo
TT = Twin Turbo
Thats interesting. I seen a few FJ20's in my time, Injected, Carbies, Turbocharged, Twin Cam. Never seen a Single cam FJ20?
You got any pics?
Posted on: 2006/2/5 10:47
