CA PARTS WANTED URGENTLY
From Wamboin near ACT(canberra)
Im in a desperate search 4 the following parts for a CA18 turbo conversion. PLEASE SOMEBODY HELP!!!!
I need:
ENGINE AND X MEMBER MOUNTS
WIRING HARNESS
Please if anybody has these or knows where 2 get them really fast i would be very grateful!! Im running out of time!
Cheers
Posted on: 2004/7/13 23:21
Re: CA PARTS WANTED URGENTLY
From Christchurch, New Zealand
I'm guessing Mad Dat Motorsport is out of the question???
Posted on: 2004/7/17 9:18
1972 Datsun 1200 Coupe
Rosso Corsa Red
14" Watanabes
Twin 1.5" SUs to go on
Extractors w/ 2" exhaust and muffler
Sony Xplod Sounds featuring Active Black Panel, 4 Channel Amp, 4 way 6x9s & 12" Sub
Quite a regular
You should PM trb012. He has recently bought all these parts and would be happy to help you.
Posted on: 2004/7/17 9:36
120y 2dr sedan, Z18t
From Melbourne,Australia
Hi mate I got my engine crossmember from mad dat motorsport.With the wiring loom give Kev Rowley a call on 07 3814-4674 he might be able to help you out otherwise you might just have to ring around interstate wreckers to find one if your having no luck
Posted on: 2004/7/19 8:45
From Warwick, QLD
Contact Andrew Denniss (CA18DET_Man) He makes up crossmembers really cheap!!!
Cheers
Damo
Posted on: 2004/7/19 11:37
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Mudgee NSW Australia
Thanks Damo Im kinda Busy getting mine going at the moment i can still do them but time is the only killer Misses is doing nigth shift so no time for work at nigth in shed im minding kids plus runing a bussiness is all taking its toll.
I have 3 to do at the moment. Im charging $280 including the new nolathane engine mounts or $200 without Ill supply the part Number. Thats with you supply the crossmember to be modified. I can reccomend Kev for his wiring looms does a good job plug in drive away type deal.Dont know how much he charges Im pretty sure he does crossmebers too.
Cheers Andrew
Posted on: 2004/7/19 13:03
If In doubt run more BOOST
