A12 Vs A12GX
From Sri Lanka
Hi Guys,
what are the engine components that can shuffle between A12 and A12GX, and what are not possible to shuffle between them
Thanks
Regards
Sumith
Posted on: 2009/1/8 3:46
Re: A12 Vs A12GX
From Darwin NT
everything can be swaped over
Posted on: 2009/1/8 3:47
current project 4x4 patrol...
Re: A12 Vs A12GX
From nowra nsw
hey datto1000wagon the guy that bought my gx carbs said that they dont fit on his head so that would make them not interchangible
Posted on: 2009/1/8 6:04
Re: A12 Vs A12GX
From Sri Lanka
Hi spenc
That might be ,because GX carb is Duel Barrel Carb where normal A12 carb is single Barrel,
Here i am asking about the Engine Parts inside the engine not outside components
Isn't it Datto1000Wagon ?
Thanks
Regards
Sumith
Posted on: 2009/1/8 6:28
Re: A12 Vs A12GX
From Darwin NT
inside engine parts are the same but the gx uses a better crank flat top a better cam and as most of us know a different larger port head so if you change the a12gx stuff into the a12 use the gx head
Posted on: 2009/1/8 6:35
Re: A12 Vs A12GX
From nowra nsw
k cherrs
Posted on: 2009/1/8 8:11
Re: A12 Vs A12GX
The A12 GX engine uses the same crank as a regular A12. Some GX even use the same pistons, but most have flat tops, same part number as the Datsun 1000 Coupe A10 engine.
A12 GX "insides" are the same except for pistons and camshaft.
Now the B210T twin-carb engine is altogether different and A12 GX engine.
Posted on: 2009/1/8 8:53
Re: A12 Vs A12GX
From Darwin NT
didnt the a12gx have a better balanced crank or something im sure ive read something like that here on the forums
Posted on: 2009/1/8 8:55
Re: A12 Vs A12GX
Not that I recall. The crank in all A12 engines is balanced.
Posted on: 2009/1/8 8:58
Re: A12 Vs A12GX
From nowra nsw
yep im with datto 1000 wagon i read that the gx had a balenced crank only
Posted on: 2009/1/8 12:49
