#1 A12 Vs A12GX
Sumith Posted on: 2009/1/8 3:46
Hi Guys,
what are the engine components that can shuffle between A12 and A12GX, and what are not possible to shuffle between them
Thanks
Regards
Sumith
#2 Re: A12 Vs A12GX
datto1000wagon Posted on: 2009/1/8 3:47
everything can be swaped over
#3 Re: A12 Vs A12GX
spenc Posted on: 2009/1/8 6:04
hey datto1000wagon the guy that bought my gx carbs said that they dont fit on his head so that would make them not interchangible
#4 Re: A12 Vs A12GX
Sumith Posted on: 2009/1/8 6:28
Hi spenc
That might be ,because GX carb is Duel Barrel Carb where normal A12 carb is single Barrel,
Here i am asking about the Engine Parts inside the engine not outside components
Isn't it Datto1000Wagon ?
Thanks
Regards
Sumith
#5 Re: A12 Vs A12GX
datto1000wagon Posted on: 2009/1/8 6:35
inside engine parts are the same but the gx uses a better crank flat top a better cam and as most of us know a different larger port head so if you change the a12gx stuff into the a12 use the gx head
#6 Re: A12 Vs A12GX
spenc Posted on: 2009/1/8 8:11
k cherrs
#7 Re: A12 Vs A12GX
ddgonzal Posted on: 2009/1/8 8:53
The A12 GX engine uses the same crank as a regular A12. Some GX even use the same pistons, but most have flat tops, same part number as the Datsun 1000 Coupe A10 engine.
A12 GX "insides" are the same except for pistons and camshaft.
Now the B210T twin-carb engine is altogether different and A12 GX engine.
#8 Re: A12 Vs A12GX
datto1000wagon Posted on: 2009/1/8 8:55
didnt the a12gx have a better balanced crank or something im sure ive read something like that here on the forums
#9 Re: A12 Vs A12GX
ddgonzal Posted on: 2009/1/8 8:58
Not that I recall. The crank in all A12 engines is balanced.
#10 Re: A12 Vs A12GX
spenc Posted on: 2009/1/8 12:49
yep im with datto 1000 wagon i read that the gx had a balenced crank only
