boofheads on the way to quad throttle EFI !! manifold pics up
finally got the manifold sorted ... now onto the fun stuff !
Posted on: 2010/5/1 4:01
Edited by boofhead on 2010/5/8 5:59:51
Re: boofheads on the way to quad throttle EFI !!
From Ballarat Victoria
Well done! They look great, well worth the wait!
Winton July 4 sounds like the time to test them!
Have you decided what ECU to run?
You might be able to use a dissy out of an EFI pulsar for your ref. and sync. signal.
Posted on: 2010/5/1 4:13
VIC DYNO HIRE
From brisbane
That will sound magnificent.
Posted on: 2010/5/1 5:27
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Haven't quite decided on computer but megasquirts looking good, specially with the backup service from this site now ;)
but then I've got a mate down here who's pushing for microtech lt8 or something ?
Was thinking crank angle for the trigger or mod the bluebird electronic that's in there ?
Always open to suggestions tho ;)
Posted on: 2010/5/1 6:47
From Melbourne, Australia
sexy stuff!
Posted on: 2010/5/1 6:59
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Melbourne Vic
microtech are simple overpriced crap. Megasquirt it! looks good mate, and seriously there isn't heaps to it once you have the manifold made... sort of :)
to save you a heap of hassle you can just but them all made, and get a loom.
the simplest way if you are happy running batch fire injection and wasted spark is run a crank trigger wheel and sensor. easy and cheap.
megasquirt have just come out with their latest version that can do sequential injection and ignition for up to 8 cylinders if you wanna start getting complex
Posted on: 2010/5/1 8:17
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
I have a loom for a Motec M4 to suit the mighty A.
Comes with all sensors, fuses, relays, coil and incluing crank trigger. $350. And an M4pro, sequential, logging, traction control etc. $1400.
Posted on: 2010/5/1 8:23
From Melbourne Vic
Mighty Motec!
Posted on: 2010/5/1 8:30
does that come with a free hub dyno tune for the mapping too simon ;)
Posted on: 2010/5/1 11:20
tomorrow i'll have the manifold and TBs arart and ill chuck up some pics ...
the runners are pressed to shape to suit the oval ports and also the TB dia.
all out of one peice of alloy tube, rather impressive and the internal change is nice and smooth ;)
Posted on: 2010/5/2 9:48
