Fitting a 910 LSD diff to a 1200 ute
From New zealand
Hi
Wondering if anyone has done a 910 diff conversion to a 1200 ute ? Or if anyone has any info on the diff,
I assume it would be a wider diff ?
And would require all the usal diff mods when converting into the ute.
Any help would be great thanks !
Posted on: 2014/8/26 23:15
Re: Fitting a 910 LSD diff to a 1200 ute
From Fremantle, West Australia
the 620 ute diff is H190 and about the same width as the 1200
Posted on: 2014/8/26 23:31
From Penrith, Sydney, NSW
So when you say 'about the same width as the 1200', does it fit straight in or do you still need to get shortened?
Posted on: 2014/8/27 4:27
"If the doors of perception were cleansed, every thing would appear to man as it is......infinite"
I got the info somewhere on this forum
from what I read, no shortening required, brakes need to be sorted and axle flanges machined down to remove 6 stud and drill fresh steel for 114.3.
Not sure about the springs
Posted on: 2014/8/27 5:56
From sydney australia
The spring perches have to be swapped to the 1200 ones, simply because the original perches are too wide & the centre locating hole is bigger. Thats the hole the bolt head sits into & if its too big, the whole housing will move. A Bluebird (910) housing would be too wide by about 100 mm. The S12 Gazelle housing is narrower than the Bluebird, by about 50 mm.. You could also try for the H190 diff housing out of an A15 powered Vanette, they have either a steel 4.1:1 ratio, or an alloy 4.6:1. Unfortunately they do have the same axle size as the H165, so this is a limit on what you can put in the front.
Posted on: 2014/8/28 10:49
From New zealand
Thanks !
I'm looking into options on upgrading the diff to a stronger LSD diff to handle a ca18det conversion .... I have a h165 that's not an LSD and don't think it would last very long with a ca18det in front of it running 16 psi ! I haven't looked into h190 much .... But if it has the same axles as a h165 their would be no difference in doing the conversion apart from the LSD ? What about other nissan diffs ? Like the navara ? I'd say it would have to be shortened and converted back to a 4 stud to
Posted on: 2014/8/28 23:12
Be aware take care avoid life in a wheelchair
Dattos - 1200 ute 4agze, 1600 L18 twin Su, 1600 ca18det
Current - building a ca18det 1200 ute and drag 1200 ute undecided on the donk !
I supply H190 LSDs direct from Japan for peeps with sr20det,
ca18det, full works L20 and LZ20 big power/tq engines
The ones that went into 1200 and old classic fairladys
used shortened 114.3mm x 4 stud Bluebird or vanette Diffs.
These LSD units are clutch pack (CP) units unlike
viscous they are re-buildable when need be.
Also most reputable diff places can cut up kevlar composite
packs for any CP unit as done for my old Alfa LSD CP units
which unlike Nissan were like weak Italian baby wipes.
Posted on: 2014/8/29 5:40
From New zealand
Sweet !! What do you charge ?
Posted on: 2014/8/29 9:01
Posted on: 2014/8/29 10:23
I've got one of D's H190 LSD's on order, if the bank transfer ever clears. I'm putting it into an S12 Gazelle housing, with a 4.1 ratio from a series 3 bluebird wagon. The difference between the Vanette H190 & the Gazelle H190 is the axle size, with the Gazelle ones being bigger & 29 spline. I think the Gazelle & the Vanette diffs are the same width drum to drum, but mine is going into a Sunny. I don't think they would fit under the back of a 1200 ute.
Maybe you could find the H190 rear end from a Datsun 1600, which might fit under the ute rear end with front wheel drive offset wheels, OR flares. I'm sure on of D's centres could be fitted.
Posted on: 2014/8/30 1:46
