need confirmation on a14/a15 mounts
hi, ok so ive read up heaps on a14/a15 install and ive found some conflicting posts about installing a14/a15 engines into a 1200. mine is a 71 wagon and i live in QLD australia.. OK, so the best solution i have found so far is making up a couple of metal blocks to attach the engine to the original engine mounts.. I have found the measurements in a previous post and this method looks the best.. but another post says that i need a 120y crossmember and a drag-link to modify to fit it.. can anyone confirm with me the best option? thank you all very much
Posted on: 2006/2/20 3:28
Re: need confirmation on a14/a15 mounts
From Brisbane, Australia
The nicest way is to use a late model ute crossmember if you can get hold of one. This way it will bolt straight in.
A bit of flat or angle steel will get it in otherwise.
There is no need for anything from a 120Y.
Posted on: 2006/2/20 3:39
From Townsville, Qld
hey did oyu still wan't to pop over and check out my stuff? if not would still be cool to see my car
Posted on: 2006/2/20 13:22
From Adelaide, Australia
I have two sets of mounts for a12-a14/15 $50 + postage if interested... pm me.
Posted on: 2006/2/20 13:39
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Best option is to use a 1974-up B120 crossmember. The part number was mentioned here a week or two ago.
next best option is to cut the existing metal bracket, lower and move them and reweld. That's what I did.
Easiest option is to use flat adapter plates, but i'm not sure you can get the engine level when doing this.
Posted on: 2006/2/20 22:28
thats excellent guys cheers
Posted on: 2006/2/21 1:49
