LSDs???
From Bendigo, Victoria, Australia.
Ok. now before you all say "read the tech section" ill tell u ive read it numerous times!!
my question is, whats the easiest LSD to fit into a 1978 B120 with a H165 already in it?
i'm not to worried about tailshafts matching up at the moment because i will get one made to suit when i get the A15 in and a celica 3T box with dellow conversion bell housing.
id just like for anyone out there running a 3T gearbox to shed some light on what diff (preferably LSD) they have in.
Posted on: 2006/2/20 10:20
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
Re: LSDs???
From sydney
Ths might be obvious, but a Nismo H165 LSD is a bolt in , very easy.
Posted on: 2006/2/20 11:28
Re: LSDs???
From Sydney, Australia
A member called TOPGEAR here was maling them a while back, I'm sure they'll set you back a bit but will be cheaped than ordering one from nissan. Better jump on the wagon quick before he finalises his orders if he hasn't already.
Heres the thread regarding them.
Hope this helps
Henry
Posted on: 2006/2/20 14:27
Any one seen my ute??? Stolen 2 years ago.
Burgundy 1200 Ute, as pictured in my avtar. Please PM.
Re: LSDs???
From Burbank, CA
i've been thinking that a virtual LSD could be done on datsuns with rear disks. It's like ABS, you watch the speed of each wheel and use modulation of the LR and RR brakes to control the wheel spin. Lots of new cars use this and I was thinking that i was a bad system but getting and maintaining a LSD is worse. This LSD also is controlled with a knob from open to maximum traction.
obviously you'd need rear disk brakes first.
maybe someday i'll get around to actually making it work.
Posted on: 2006/2/20 20:19
|||\ 81 KPB310 /|||
Re: LSDs???
From Taupo New Zealand
fwiw I think the Nismo LSD has gone out of production.
Posted on: 2006/2/21 8:48
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
Re: LSDs???
From Adelaide, Australia
Using brakes to gain traction under acceleration
Posted on: 2006/2/21 8:53
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: LSDs???
Yeah its called traction control
Posted on: 2006/2/21 9:19
Re: LSDs???
From sydney
Maybe , but they are still pretty easy to pick up, if not pretty cheap.
Posted on: 2006/2/21 9:26
Re: LSDs???
Doesn't Pitroad still advertise the LSD.
Posted on: 2006/2/21 9:36
Re: LSDs???
I would have never thought a traction control system would use brakes though, i thought it was just a lsd that was more sophisticated and just reduced power to a wheel if it started to spin.
Posted on: 2006/2/21 9:46
IPRA Build
(1) 2 3 »
