Can I fit my smaller A12 dizzy to an A14?
From Sydney
Ok
Posted on: 2006/2/27 6:56
Every dog has it's day... except hyundai's.
Re: Can I fit my smaller A12 dizzy to an A14?
not 100% sure, only difference i can think is between the early ('73 and before) and later blocks you cant because of distributer location : early - at number one spark plug. late - between 2 and 3 plugs. still not sure if there is a difference in the actuall dizzy ??? but what you really should look into (especially with all your other new bits going in ) is one of these little puppies at the bottom of the page definitley a faultless upgrade
Posted on: 2006/2/27 7:51
Well, I haven't actually tried it, but I can't see why it wouldn't work. Just modify the bolt-down bracket similar to the new-to-old swap.
Posted on: 2006/2/27 7:58
From SE Melbourne
I've got some comparison pictures of the 2...but if you have both I think the A14 dizzy is better - better able to handle high rpm
Dizzy thread
Posted on: 2006/2/27 8:39
Mildman, Datsunless
From Burbank, CA
it seems possible, but why?
Posted on: 2006/2/27 9:01
|||\ 81 KPB310 /|||
you can use them, just swap the base plates... also make sure you dont accidently get an electric dizzy, you must sell it cheap to me :)
Posted on: 2006/2/27 10:48
If you plan to use the distributor from a 1970 to '73 Datsun 1200 engine, then you will need to switch the stamped steel mounting plate from a 1974 or later distributor. If the new distributor is from a 1974 [120Y] or later A12, then I believe that it will drop straight in.
The advance curve will be diferent, but the engine will probably run just fine anyway.
Posted on: 2006/2/27 13:08
Love your Datsun.
Treat it well.
it runs fine, once you install it, with the new base plate....it does drop straight in, conversely you can do the same to run a later model dizzy in a pre 73 a12.... and they tend to run better (from my experience)
Posted on: 2006/2/28 6:37
