Ute - No Power
From Brisbane
I was installing my alternator and tried starting the car and no starter motor click, no lights battery is kinda new, even though its the battery how come I'm not hearing the started motor engaging with the click sound?
Last time I installed the alternator a wire coming from the battery white and red strip made a small amount of smoke on the plastic harness.
Tried disconnecting that harness and cleaning the contacts no luck
Anyone please help me need to get the ute running again
thanks
Posted on: 2006/3/15 8:38
Re: No Power
From Brisbane
I tried the screw driver on the starter motor big terminal to solenoid and it click once and turned the engine also made a spark and thats all tried again and it wont click or turn over
does that mean the solenoid died after the alternator install that shorted?
Posted on: 2006/3/15 8:50
Re: No Power
From Brisbane
OK I tried it again I made a wire connected it to the solenoid and touched it to the battery + side and its cranking but it wont start
so that tells me the solenoid is good right something wrong with the wire on the ignition switch side?
Posted on: 2006/3/15 9:01
Re: No Power
From sacramento california
i can help you. go over this checklist. if it isnt one of these than its fubar.try to start it after each.
-replace the power cable on the batterey, and the small accesory wire
-replace the ground cable
-check your transmision wires (automatic only) make sure that your park neutral swith is connected.
-check your fuse box for blown fuses
-see if your ignition is loos on the steering colum.
if turns over but wont start
- check your coil wire
-check to see if you have spark
if non of these work ask me again and ill tell you some even smaller things to check
Posted on: 2006/3/15 9:59
Re: No Power
From Brisbane
Hey casper thanks for the reply
from what I tested the engine is cranking nicely if I short the strarted solenoid to +ve side of battery but wont do anything at all if I try to start it with the ignition key and also no power.
The external regulator harness is now disconnected for the alternator with internal regulator
checked the fuse under the dash/steering side and no blown fuse/fuses
*remember this no power problem only occured while on alternator swap
Posted on: 2006/3/15 11:29
Re: No Power
From Alabama, U.S.A.
Hey Razor , did you read the tech section on swapping to an internal reg. alternator. There is a wire that needs to be cut & hooked together. That is where your problem lies if you didn't make this change.
Posted on: 2006/3/15 12:06
Re: No Power
From Brisbane
Yeah I read it but not sure which wire you're talking about...
I disconnected the regulator harness and placed a single jumper wire
connected the earth wire, battery wire and the idiot light "F"
can you let me know which wire was that?
Posted on: 2006/3/15 12:18
Re: No Power
From Canberra
the two little wires on the back of the alternator (I think there's 2 little and one big) If you get them the wrong way around you'll have symptoms like you describe. I was sure I did it right and fiddled with everything (fried a good section of loom in the process ) Then decided to switch those two wires around and away she went.
dont know if this helps you... but it might
Posted on: 2006/3/16 2:30
Re: No Power
This thread and its contents makes me laugh. Thanks
Posted on: 2006/3/16 3:09
Re: Ute - No Power
From Tracy ,Ca
ok you probly brunt a fusible link the wire was good until you let the smoke out
Posted on: 2006/3/16 6:14
