« 1 2 3 4 (5) 6 7 8 9 »
Re: manufacturing turbo kits!?!?
I see where they are coming from.
I also see lots of thoughts but not much knowledge getting used.
Just my thoughts and observations.
Posted on: 2006/3/16 4:40
From Cronulla
Sure i know motor's run on "gasoline" and lots of other fuels , you learn a few things about cars being a mechanic. Anyway i am stating to think that you might be a terrorist casper17000, trying to sell bombs (intercooled turbo kits) to innocent datto owners...
All the best fuk face..
Posted on: 2006/3/16 8:30
From sacramento california
man, if you really want an intercooler on a draw through system make it yourself. otherwise dont critisize. i ahev a couple buddies helping on these parts so they should most definatly turn out as works of art. no hard feelings.
Posted on: 2006/3/17 1:31
It doesn't matter how pretty it looks, if you intend on using a draw through weber carb and an intercooler you are going to blow the front of your car off!! as simple as that.
It looks like your going to have to work out how to make a blow through setup if you intend on using intercoolers. If this was your plan then PLEASE tell us more!
Posted on: 2006/3/17 2:57
From Burbank, CA
the intercooler thing was solved like a page ago.
chill
Posted on: 2006/3/17 3:41
|||\ 81 KPB310 /|||
ok, i dont wanna say it again so here.
kit #1-drawthrough non-intercooled
#2-blowthrough intercooled.
i never once said i was going to make a drawthrough with an intercooler. yes, i do agree that would be incredubly stupid to have a drawthrough with an intercooler. ill make another post in a bit with what components i will be using (turbo's, intercoolers.etc)
From western nc
casper i gots faith in ya ole boy. prolly do alot better en me. just wonderin if you can use a blow off valve on a blowthru? not too literate on the turbo aspect here. also the fact i've got an auto so is it gonna be necessary to convert trannies now?
Posted on: 2006/3/17 5:28
"from the forest itself comes the handle for the axe..." -Matisyahu
I'm chilled. I'm not even interested! This thread just looks like the blind is reading the blind.
Posted on: 2006/3/17 8:16
yea, you can use a blow off valve if you remove the internal watsgate. i dont think youll have to convert trannies. the blow off valve will go on the inlet pipe into the intake manifold. the first series is for the ovalport head design. i dont think it will make a difference in heads because i am utilizing the stock intake manifold. the exhaust manifold i am fabing should bolt up and seal to round and oval port heads.
Posted on: 2006/3/17 9:37
Yep definately blind. Confuzed is a good word too.
Posted on: 2006/3/17 9:42
